What does Err 60 H 1 mean? - Heating & Cooling
  • 92 Answers
What model/brand of heater are you referring to?
Posted on May 11, 2014
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
What does err 4 mean and how can I fix it?
Err 4 means there is an error on your camera. Unfortunately, each camera manufacturer uses the same code for different problems. Please contact the manufacturer for further information.
Nov 17, 2016 | Cameras
What does error code Err 09 for a Wolf oven mean?
Hello Joni;
My name is Peter. I am a retired field service appliance technician.
The error coded means: Short circuit in PT sensor or in its wiring.
Feb 03, 2015 | Wolf Range Kitchen Ranges
Err 68 what it means and how too fix no fule too motor
Err 68 means
Err 68 Hold-in Relay ON. Output from the Display is short circuit. No fuel to the engine. Contact your John Deere dealer
Aug 24, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Microwave not working stating error 3 or error sensor or just coming on by itself. we have tried shutting down circut breaker
Hello
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
This code is different than "ERR 1" or "ERR 2" because with those the microwave is still operational. "ERR 3" means a complete failure.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Oct 04, 2011 | Microwave Ovens
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | KitchenAid Kitchen Ranges
Hunter src plus irrigation panel- Getting a PErr message what is that?
A "P Err" readout means there is an overload in the pump/master valve circuit. A readout of "1 Err" means there is an overload in station No. 1, while "2 Err" means an overload in station No. 2 and so on, depending on the number of total stations being operated by the controller.
An overload occurs when the wiring circuit is requiring more than .56 amps of current. This overload will typically occur when the field wiring or valve solenoid is shorted, or if the field wiring is a smaller gauge than required for the application and/or distance.
Apr 02, 2011 | Garden
Hi sometimes it takes a picture with no problem but sometimes I get err 99 or err 01. Any ideas?
Hi! Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for choosing Fixya!
Feb 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
How do you reset CD player in a 300M Chrysler 2004 ERR is on the display
that means the cd needs to be serviced the re is no reset procedure ERR means th eunit has failed and needs service
Aug 07, 2009 | 2000 Chrysler 300M
Pioneer cdxfm128 12 disc changer
Err 11, Err 12, Err 14, Err 17
Dirt or a scratch on the disc stops the laser
beam from being able to focus.
Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
Nov 15, 2008 | Car Audio & Video
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
