Question about Sub-Zero 632 / S
Sub zero 700br shuts down
Sub zero 700br2 underCounter unit. It works fine and cools nicely. Just suddenly it will shut down. I can start it up fine via the control panel. Sometimes it works for 3-5 days then just shuts down. What I have done: made sure the condenser coils are clean and lint free, turned the unit off for 10 minutes at the breaker to reset, when unit is on air is sucked through the coils and it gets warm - plus no problem on it working, reset it by holding the start button and temperature heard the clicking and reset, no error codes appear, or any codes at all. My thought is it is the thermistors and there are two of them to replace. Possible the temperature get too cold then just shuts off. I would appreciate your suggestions. Thank you Kevin
  • 3 more comments
  • Kevin933k May 12, 2014
    Thank you for your great response.
    Add a Comment. I did take off the panel on the bottom drawer and looked inside- no ice or icing. It was clean. I also put it into diagnostic mode and received the following details; 43 L, 37 E and 46 O( or might be a U).
    From the diagnostic measurement "37 E" is appears low freon is not an issue.
    Just complete another service check - 42 deg "L", 35 deg "E", and 43 deg "U".
If this machine takes to much time to get to temp. Or doesn't shut off once it reaches the right temp then the board will sense a problem and shuts it down. It could definitely be a thermistor causing the problem. I work on tons of these machines. Onetime I fixed a customers machine that had a leak in the sealed system. I fixed and charged it with freon it was working perfect when I was there. The next day customer called the machine was off I went there couldn't find any problems. Restarted it same thing next morning it was off. Long story short the man had it so filled that it was taking to long to get to the right temp it was shutting down. So the next time it shut off I showed the customer how to restart it before it lost temp. Never had anymore problems.
Posted on Jun 24, 2014
Rotu
  • 175 Answers
SOURCE: Subzero 700BR Refridgerated Drawers Not Cooling
If your unit is new enough to have an on/off button on the keypad, then put it into diagnostic mode by pressing and holding the "colder" button, the pressing the on/off button at the same time. the display should change and it should read a temp like 67r or 67e. you can scroll back and forth through the 2 temp readings by pressing the colder key. If the fridge has been running, the temp of the one ending in "e" should be no more than 38. If it is, then you most likely are low on freon and will need to have the evaporater replaced. The part will be covered under the 12 year parts warranty, but the labor will only be covered for 5 years.(from date of install, not date of manufacture printed on the lable) If you want to go into it more, take the lower drawer out and remove the 6 screws holding the panel to the floor inside the fridge, then slide out the floor panel. Look at the coils in there, and if you see a ball of ice on the left hand side, you have a freon leak and the above repair is what youll need to to. if its older than 5 years, ecpect to pay about$500 to have it fixed...it's a mojor pain. If its less than a year out of the 5 year, call subzero...theyll probably take care of it for you anyways. Good Luck!
Posted on Jul 18, 2007
Rotu
  • 175 Answers
SOURCE: Sub-Zero 650/F
get into diagnostic mode by pressing and holding either colder key, then pressing on/off. You can use the colder key to scroll through 5 reading labeled fe, re, f, and r  look at the re temp. is it higher than 38? if it is you probably have a freon leak in the evaporater refridgerator (call sub zero...they will completely pay for this issue, even past the 5 year warranty)  If the temp reads really low (like 10 on re or something) you probably have a bad fan or fan switch in the fridge portion. this unit has seperate compressors and freon for the fridge and freezer..hence the lack of problems in the freezer. hope this helps!
Posted on Oct 24, 2007
  • 125 Answers
SOURCE: sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Posted on Jul 19, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Posted on Mar 27, 2009
wheelshot
  • 102 Answers
SOURCE: 650 sub zero that has a vacuum condenser message returns.
I have seen this many times and have fixed the problem many times. You may notice a ball of frost or ice build up in the fresh food compartment, This is because you have a leak in your evaporator coil and it needs to be replaced. It is a pretty costly repair but well worth it in consideration to what you paid for this unit or what the cost of a new one would be. Because it has less freon in it is why the compressor is running longer and causing message to pop up. Have the evaporator replaced in the section that is giving the issue and this will solve your problem with the unit.
Posted on Apr 11, 2009
Undercounter subzero 245 refrigerator box not cooling yet ice maker working fine
Is the fan running? Has the door been left open? That unit has an automatic defrost and if the coil doesn't get cleared of frost it won't circulate air.
Oct 17, 2013 | Sub-Zero Refrigerators
Power returned after storm. sub zero works but not ice maker. what to do?
Please shut down the fridge for about 6 hours, restart and then check if there is cooling . It is possible that the power outage could have reset the settings and so by resetting to normal condition it must work .
Sep 02, 2011 | Sub-Zero 690 Side by Side Refrigerator
It is a Bryant Legacy AC unit. Model #123RNA060-B. It has been running fine, now it has suddenly shut down. The interior fan is working, but the fan at the compressor shuts down. It will work fine for...
I had a unit do the same thing to me, everytime I would leave, it would stop working again. I had a bad fan motor that would spin fine and work for a little while, but would shut down. It was the motor windings that would overheat and shut off, as soon as they cooled, it would start back up. One way to check is to feel the top of the unit where the base of the fan mounts and see how hot it is, best to check while it's not working how it should, but try not to run it very long or you could damage the compressor. Hope this helps!
Jun 27, 2011 | Bryant Heating & Cooling
Sub zero 561, evaporator is icing. 1st tech came in and after checking gas pressure told us that evaporator is leaking. we called in secong tech, he filled up gas and it started cooling fine but couple...
It may be leaking but I think more likely is that you have a problem with the defrost system and it is not defrosting properly... that can give the same symptoms as a low charge or leak condition...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Sub-Zero 561 / F
Sub Zero side by side frig. side not cooling. Freezer works fine
There is a fan inside the freezer and possibly the fridge. It circulates the cold evenly throughout the unit. The fan may shut off with the door open so hold the door switch in to see if you hear the fan. It's behind the rear cover on the inside.
Sep 11, 2009 | Refrigerators
We have our Sub Zero model 650 frig set to 35 degrees, our usual temp, but suddenly it won't get lower than 50. Freezer seems fine.
Check for a fan motor in between the freezer and the fridge. Or you have a block of frost in there shutting off air flow.
Jun 28, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 632 / S Logo
151 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Steve
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
