Question about Thermador SC302T Electric Double Oven
How do I remove the element? - Thermador SC302T Electric Double Oven
  • 92 Answers
If this is not it, I suggest you search the site linked below until you find what you want ...
http://www.appliancepartspros.com/bosch-bake-element-30-367648-ap2826720.html
k
Posted on May 11, 2014
When I switch the bottom oven switch on the fuse blows in the electric box. Please can you advise if a wire is loose and how to fix it.
Sounds like your element might be blown and shorting. Switch the appliance OFF. You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
Mar 31, 2011 | New World Ovens
The element has blown on my Zanussi ZBF860 oven. I
Mar 15, 2011 | Zanussi ZBF360 Electric Single Oven
How do you replace the bottom heating element
Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element.
To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 09, 2011 | Ovens
Removing oven element to install new one
Turn power off at service panel (220 volt circuit breaker). Remove screws from heating element mount on wall of oven. Pull heating element from wall of oven far enough out to see the where the wires/lugs are screwed to the heating element leads. Remove these screws. Replace element. Make sure screws on heating element lugs/leads are tight -- if not tight, arcing will occur.
Charlie
Jan 08, 2011 | Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
Jenn-air ww30430w dual oven, lower oven, lower element not heating, upper broil element working fine
Most likely a bad element. Turn off the power to the oven. Remove the racks.
Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
A new element will correct your problem.
If the element reads as good you have a wiring problem or a bad control.
Jan 03, 2010 | Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
Jul 29, 2009 | AEG U7101-4 Electric Double Oven
Fitting a new heating element Neff U1721
You need to remove the element from inside the oven cavity, but it is a bit of a fiddle. Once you have removed the screws at both ends of the element you need to remove the fan blade to access the centre fixing screw. Once all srcews are remove you have to twist the element and pull forward to remove the wires from the hole on the left, then remove the wires and refit to new element.
Jul 11, 2009 | Neff U1721 Double circotherm Electric Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
37 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
