Question about Boating
I have a 1996 200hp evinrude vindicator . for some reason i have no spark on the port side cylinders?
2 Suggested Answers
  • 2826 Answers
SOURCE: why no spark on bottom cylinder 68 evinrude
Check distributor cap for cracks, wires for same, breakage.
Posted on Oct 08, 2014
I have a 490 horse evinrude outboard lost spark wont start
Never heard of a 490. Decades ago, Evinrude made a 4 cylinder (V4) 90 hp. It would be helpful to know the approximate year of the engine!
Sep 05, 2017 | Boating
Tip
Attention to spark plugs
Pay attention to what spark plug comes from what cylinder, and save the old spark plugs. The cylinders are numbered from 1 to 8 as follows: Front of car Left side - right side Cylinder Bank 2 - Cyliner Bank 1 5 - 1, 6 - 2, 7 - 3, 8 - 4, Rear of car. The reason for keeping track of the old spark-plugs is it can later provide important information to a person who knows how to "read" spark-plugs, if the engine ever develops a problem. Also it is good practice to put the coils back in the same places those were.
on May 19, 2008 | 1988 BMW M5
I HAVE A 1978 EVENRUDE 35 HP NO FIRE TO THE PLUGS GREAT COMPRESSION???
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
Nov 26, 2015 | Boating
How do I test ignition,points,coils ect.on 68 evinrude 9.5 sportwin?
Same way as you do on a car. You missed the spark plug wires. Look for corrosion on the rotor cap and measure the resistance of all the spark plug wires .
The high resistance ones need changing.
Oct 01, 2014 | Boating
Where can I find the serial number on my Evinrude 20H motor?
There is a plate or sticker on the Port transom bracket or on the steering bracket ( between both transom brackets ).
On very old engines the plate is rivetted on the steering bracket at the front of the engine.
If you can't find a plate or sticker anymore, there is a aluminum 'freezeplug' with the serial number stamped. You'll find that plug in most cases at the starboard side of the engine block near the cilinder head, or on the top of the cilinder block.
Apr 13, 2014 | CDI Electronics Johnson Evinrude Boat Side...
1990 Johnson 150GT no spark to port side of engine,no voltage to coils..
Port side power pack has failed most likely. Replace it and test.
Go to: http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
look your part # up and shop for the best price. I like ebay.
Hope this helps.
Lewis Hot Headz Marine
Sep 25, 2013 | Light Outboard Motor Boat Bass Fishing...
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
Evinrude 25 pk 2 stroke 2cyl outbord boatmotor
Hello enjoy42. From the information you have provided I would lean to the weak cylinder coil. Unplug the good spark plug wire & test run the engine on the weak cylinder. You could go to swapping the coils on the cylinders. Check your wiring terminals on the coils. Check with a marine dealer for the correct plug. I owned a 35 Evinrude on a Bass boat & it would out run my buddys 40 Mercury. Good Fishing.
Oct 01, 2008 | Boating
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
