Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Pentair 1 1/2 hp pool pump loses pressure when i plug in vaccume but skimmer works
    Champion:
    Scholar:
  • Zodiac Expert
  • 239 Answers
If you are using a vacuum adapter, be sure that the drain opening to the skimmer is closed. there should be a little flap door that swings over the drain opening
Posted on Oct 05, 2014
2 Suggested Answers
  • 366 Answers
SOURCE: when our above ground automatic
I think you meant that the pump keeps filling with air. You may have an air leak on the suction side of the pump. If you turn the pump off, you should not see any water leaking out of anywhere, if you see any water drip near the suction side of the pump, you should consider that an air leak and repair it.
The problem you're having seems to be an air leak. when you connect the manual vacuum or if the system is running normally, there is not nearly as much suction that is created as when the zodiac is plugged in. The air is forcefully pulled into the system when increased suction is created.
Try replacing the lid o-ring and investigate any possible places on the suction side of the pump that could be a potential leak.
Hope this helps.
Posted on Aug 01, 2011
I have a pentair cartridege pump for my inground pool. In the skimmer basket there are 2 holes.one to the pump and one to the main, it looks like the one to the main has something blocking it. on the
all inground skimmers have 2 holes some pools use the front one for a equalizer that is if you pool water gets low the skimmer will still work if no hole in the side below skimmer it will be plugged sometimes pool builders mix them up and use the back one for the equalizer like I said if no round hole on wall below skimmer just disregard
Jul 06, 2014 | Pentair Pool & Spa
Pentair 1 1/2 hp pool pump works while skimming but loses prime when vaccum gets plugged in
the pump is doing what it was designed for any difference in suction will make it error out you might have to set it on manual to vacuum
May 11, 2014 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Hello, I have a pentair whisperflo 1hp pump and it seem to have very little water pressure coming into the basket and my skimmer has very little suction as well. Any suggestions Thank you, Ali
turn the pump off, remove the lid and pump basket. reach your finger inside to see if there is any debris caught in the impeller. MAKE SURE the pump cannot come on at any point while you're working on it.
That should do the trick, if not, investigate an air leak on the suction side of the pump. Causes: bad lid 0-ring, threads on suction fitting leaking air in, or if there is a union on the suction side, make sure it's tight and the o-ring is in good condition (add lube as necessary).
Aug 01, 2011 | Pentair Whisperflo 1 HP Pool Pump WFE4...
When I turn on my pool filter with a Pentair WhisperFlo 2 hp pump, the psi has jumped from 18 to 30. There's nothing visible in the baskets in the skimmers or in the WhisperFlo. Where could the resistance...
If your pressure has gone up, the problem will be on the discharge side of the pump. First, make sure that your gauge is not malfunctioning.
Next see if all valves after the pump are set properly and that the three way valves or backwash valve are not broken inside.
Is this helpful?
Gary
Feb 28, 2011 | Pentair 2 hp WhisperFlo InGround Pool Pump...
No suction for pool vac
If you are not getting any suction to the vacuum, but the pump is working fine the rest of the time, start by checking all of your connections that conncets the cleaner to the filter and pump. Make sure there are no cracks, lose hoses, etc. Then, check for the following common problems with your pump that might cause low pressure in pool pumps:
1) Pump not primed
2) Leakage of air into suction system
3) Impeller clogged
4) Valve in suction or discharge line partly closed; Suction or discharge
line partly plugged or too small.
5) Plugged basket in skimmer or hair in lint strainer
6) Dirty filter.
Sep 09, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
When I turn the suction valve to pull from the pool only and not the jacuzzi, the pump doesn't fill w/ water and has a lot of air and the filter tank loses pressure.
sounds like you have alot of air coming from the pool. check the weir in the skimmer to make sure it's not stuck and blocking water from coming in, assuming the water level in the pool is normal.
If you have an auto cleaner, make sure the hoses are not cracked. Use a process of elimination to try and determine where the air is coming from. If you can't find anything obvious, have the line(s) pressure tested.
Aug 20, 2010 | Pentair 2 hp WhisperFlo InGround Pool Pump...
How do I relieve the pressure on the pump
Make sure that the skimmer and pump baskets are clear of debris. If they are full, an obstruction can cause pressure to build up. You might also want to re-prime the pump to relieve the pressure. Make sure that your impeller is clear of debris. All of these problems can cause pressure build up in pool pumps.
Jun 18, 2010 | Pentair Superflo 1 Hp In Ground Pool Pump
When i put my hose in to vaccum i lose suction but with out hose it will **** your hand down the pump is workin great
Are you filling the hose with water before you put your hose into the skimmer? Put your vacuum in the pool - put the other end of the hose over a discharge ... when the air bubbles stop coming from the bottom ... , put your hand over the end of the hose and then stick the hose into the skimmer suction.
Jun 04, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
The jets quit working when I prime and attach the vaccum hose
you could have a leak in the vac hose or a shaft seal on the pump, if there is a wet spot under your pump there is a good chance the shaft seal is BAD.... some pumps are so strong you can starve the PUMP for water, the trick is to set your valve more towards the main drain./ hope this helps.. i'm your local pool pump motor repair guy
Jun 20, 2009 | AO Smith 2 hp Swimming Pool - Jet / Well...
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
61 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
