Question about Cameras
What causes clicking noise un head without pain
Clicking starts randomly without notice or prior indication and without pain. Is extremely pronounced when wearing hearing aids. What could cause and what to do to alleviate aggravation
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Sorry Ruth, I think you are not in the right place with this question. Here we try to solve technical problems from lots and lots of different kind. But with a medical problem, you are better of with a physician, doctor or in a hospital.
In the country I live, even if I knew what was wrong, I was not allowed to tell you, because I have not the correct education.
Posted on May 12, 2014
Differential noise
indicates axle bearing failure rather than diff problems
diff failure is indicated by a growling noise on acceleration or deceleration or a constant harmonic hum while driving at a steady speed
from your description of where the noise is most pronounced indicates wheel bearings
Jun 28, 2017 | Toyota Tundra Cars & Trucks
What are symptoms of cracked exhaust manifold
it is from a crack in manifold. from a clicking noise to a more pronounced whistling or whooshing noise. With the vehicle running, This may be more pronounced when the engine is cold and first started. good-day! A crack is, in essence, a vacuum leak and may prevent all of the engine functions from operating correctly.( loss of power), manifold cracks can cause, exhaust odors in engine compartment.
Apr 25, 2014 | Vehicle Parts & Accessories
R1 indicators
Broken wire in the loom around the head stock is quite common.
Feb 27, 2014 | Motorcycles
FRS23KF6EBA loud noise
Hi Charlie, thank you for allowing me to assist you!
Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become common to you. This also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable. If the noise, however, become louder or more pronounced, then you may want to connect with a local appliance technician to determine if anything else may be the cause.
Jan 21, 2014 | Frigidaire FRS26H5AS Side by Side...
Noise problem with my refrigrator freezer
Good Morning Admasu, thank you for your post!
Your high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become common to you. This also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable. If the noise, however, become louder or more pronounced, then you may want to connect with a local appliance technician to determine if anything else may be the cause.
Dec 22, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a frt18drh fridg. every time it comes on I get a loud whistling sound.what can I do to stop this ?
Good Afternoon frnk, thank you for allowing me to assist you!
Oct 16, 2013 | Frigidaire FRT21H8 Top Freezer...
While driving 65 on the freeway, my car started to smoke and make clanking noises without notice. (The sound was similar to churning pop corn roasting in a kettle). It did this for a short time and the...
sweet tailpipe smell is cooking antifreeze- either a head gasket or head- or worse- if the engine spins but doesn't start if could be as simple as a head gasket- but from what you described- i would be looking for a new car or a cheap working mechanic to change the engine
May 10, 2011 | 1997 Buick Skylark
Hi, I have a Ssangyong 2007 Rexton 2 and since I bought it from new it has made a noise that can only be described as a clunk when I go around round abouts or turn right on sharp bens or turns; the...
you may go to ssangyong, mine has the same, and they say that the 2h 4x4 shift, wants to enter in function, or wants to work, they tight a Nut that is in the front left wheel near de suspension and the noise has gone... Sorry for my english...
Feb 26, 2010 | Mercedes-Benz ML320 Cars & Trucks
Loud "tire or wheel" roar on the highway
I certainly would take it back to the shop that performed the brake job and have them investigate. If it was not making the noise prior to the repair there is a good chance the noise is involved with the brakes. A possible loose brake pad, a sticking caliper(caliper pins may need to be lubed) or any number of things could be wrong.
Jul 04, 2009 | 2003 Ford Explorer
Loud tick & knocking for a 1zzfe engine from 2001 toyota corolla
from what you are describing it sounds like a lifter/valve issue, i am a ford man i don't know if toyota do the same thing, but if they use inserts for the valve seats it is possible a valve seat has been dropping just has not dropped fully out to cause engine damage. buying a new engine will actually cost you less than an overhaul/rebuild anymore. the parts will cost you almost as much as a new motor will with all the machining that maybe needed.
May 13, 2009 | 2001 Toyota Corolla
Cameras Logo
52 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
