How to change password on xfinity internet gateway
  • 37 Answers
Change my belkin router password want a diffrent password
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Try this site:
http://techchannel.radioshack.com/change-security-settings-belkin-wireless-router-1402.html
How to Change Security Settings on Belkin Wireless Router
Feb 11, 2015 | Belkin Computers & Internet
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
Find my wi-fi password
Hi Rene,
Your Comcast password is not visible to any of your equipment, if you do not remember anymore your password you may want to talk to their Tech Support 1-800-XFINITY (1-800-934-6489) to reset your password or give you hint as well for the password.
Jan 27, 2014 | Comcast XFINITY
I need to find my password to my wifi internet
The Xfinity Arris 805 and 862 and CP3939 wifi info is on the bottom of the router on the white sticker. If the sticker is missing call Comcast 1-800-226-2278
Jan 22, 2014 | Comcast XFINITY
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Forgot password for my router
On the back of your router there is a very small reset button. Hold the button down with a pen for about 25 seconds. This will reset the router to the original password. Now the password should be either blank or "admin" (without the quotations) To log on to your router and change the settings you can type your gateway ip address into the address bar in your internet browser (i.e. Internet Explorer, Firefox, Chrome, etc.) Your gateway ip address is usually 192.168.1.1 but it may vary. You can search the internet for "what is my gateway ip adress?" to find out how to get it. For more computer related help you can also visit DigiBalm.com.
Feb 10, 2013 | Linksys Wireless-G WRT54G Router
NEED SECURITY CODE FOR WIRLESS ps3 CONNECTING TO XFINITY GATEWAY
If you are connecting to a router(gateway) that has wireless security enabled you will need to enter a security code on your PS3. I wrote a tech article which explains how you can obtain this security code, or if need be, set one up. Click link - How to obtain router security key,password
-G33k
Sep 28, 2011 | Arris Touchstone 450a (CM450) Modem
Change password
access your router configiration to check what is your gateway address click start button then go programs then click accessories then click command prompt. From the command prompt type ipconfigand press enter
get the default gateway address and type that into the address bar of the Internet Explorer and press enter. you will be ask for username and password you must type your router username and password. inside the router configuration you can configure/change password for your router as well as the password for your wireless.
Sep 10, 2011 | Linksys WRT120N Router
Lost my cd to change the password
Click Start
Click Run
Type CMD
Press ENTER
Type IPCONFIG
Press ENTER to get output like:
IP Address. . . . . . . . . . . . : 1924.168.49.67
Subnet Mask . . . . . . . . . . . : 255.255.252.0
Default Gateway . . . . . . . . . : 192.168.48.1
Take that "gateway" IP-address, and start Internet Explorer.
Access http://192.168.48.1
and login as 'admin'.
Enter the current password.
Change the password.
Jul 30, 2010 | NetGear WGR614 Wireless Router
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
