Question about Whirlpool Dryers
Whirlpool dryer LER8648LW0 WILLL NOT START
LER8648LW0
    Top Expert:
  • Whirlpool Master
  • 3,698 Answers
Check safety switch on door.
Posted on May 11, 2014
3 Suggested Answers
larryyb
  • 291 Answers
SOURCE: whirlpool LER8648LW0 wont start when you push the button
check your door switch to make sure it is good / if switch is bad it will do that / larryyb
Posted on Dec 05, 2008
smitty5609
  • 243 Answers
SOURCE: replacing dryer motor model ler8648lw0 whirlpool
The easist way is to take the covers off because it is difficult to get to. Once you take the front cover off you can lift out the drum and be able to get to the motor easily.
Good luck
Posted on Sep 26, 2011
Replacing dryer motor model ler8648lw0 whirlpool dryer
Good luck
Sep 26, 2011 | Dryers
Whirlpool model LER8648LW0 - the dryer will not stop when door is opened and the interior light does not light. I have changed the bulb on the light but it still does not work. I suspect the problems are...
I suspect the problem with your dryer is the door switch as opposed to the timer...its the responsibility of the door switch to stop the dryer when the door is opened as well as turning on the light too when the door is opened.
The part number for the door switch is 3406107 it could be purchased at your local appliance parts store or online at;
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.com
partselect.com
This youtube video will show ya how to replace the door switch http://www.youtube.com/watch?v=gWQhuQXa6d0
GENE
Sep 12, 2011 | Whirlpool LER8648L Electric Dryer
I have a Whirlpool LER8648LW0 and it will not heat up. I had to change the breakers and once I did that no more heat. Everything else works fine. The only difference in the breakers is the old ones were...
if you had heat in the dryer before you changed anything in the electrical box then i doubt very much it has anything to do with the dryer.if you have a meter you can check at the block where the cord connects to the dryer and make sure you have 240 volts coming to the dryer before you start messing with the dryer
Mar 03, 2011 | Whirlpool Dryers
Why my dyer willl not get hot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Whirlpool LER5636P Electric Dryer
Dryer not heating
if takes a long time then u have a venting issue.
if no heat first check your breaker a dryer willl run on 120volts but 240 is needed for heating..
if electric check ur heating element, thermostats, thermal fuse for continuity with a meter
if gas check the ignitor,thermal fuse, or gas secondary coils..
Feb 05, 2010 | Whirlpool Dryers
LER8648LW0 Dryer. Not heating, runs continuously (stops w/ door opened). Timer not advancing. Checked fuse(0 ohms), thermostats (0 ohms) and coil (10 ohms). Timer was at 10-11 K ohms,(high end). So...
One side of the element powers from the timer and the other side from the motor . Remove one wire from the element , and check which wire is not getting 120 V . Trace the wire NOT getting 120V and it will lead either to the timer or the motor , providing that the small t-stat looking piece (thermal cut-off) located close to the top of the heater box , shows continuity . If it does not , then pt # 3392519 is for it and the hi-limit t-stat . If you replace it , then replace both that come in the kit .
Jul 16, 2009 | Whirlpool LER8648L Electric Dryer
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Whirlpool duet 9400 Washer won't do anything?
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Dec 27, 2008 | Whirlpool GHW9400 Front Load Washer
Whirlpool LER8648LW0 wont start when you push the button
Nov 30, 2008 | Dryers
Dryers Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
