Question about Cameras
Canon Rebel XT Hello I have a serious issue with my Canon :( One of the pins in the cf slot is bent down and its in the far edge so I cant reach it. Ever since is bent my Canon stopped turning on. I really miss my camera did the bent pin fry it?
    Top Expert:
  • 3,698 Answers
You can consider sending it back to Cannon to be repaired.
http://www.usa.canon.com/
Posted on May 11, 2014
SOURCE: Canon Digital Rebel XT / EOS 350D
I had the same problem; I could insert the card but it wouldn't read. I Got a CF error message. I was going to get it fixed then I realised that the bent pin was touching the adjacent pin. So I intentionally broke-off the damaged pin... an now it works perfectly! Many of the pins on CF cards don't appear to function.
Obviously, only do this if the pins are touching and you can't bent the pin back straight. You could make thing worse by rummaging aroung the CF slot, but as I was going to send it away anyway, at some considerable cost, I had nothing to lose.
Posted on Sep 18, 2008
  • 10 Answers
SOURCE: No Power To Canon Digital Rebel XT
Change out the CR2016 3V battery. You have to remove the rechargeable battery to get to the CR2016. Refer to the manual for proper instructions.
Had the same issue with a two year old camera. This solved my problem.
Posted on Jan 01, 2009
mcomijohns
  • 477 Answers
SOURCE: Canon 10d digital camera Err 02
Most likey your problem is the cf card reader when ever the camera was made they could have not heated up the board all the way causing a cold solderjoint after time this joint becomes week and gets disconnected on the back side no visual damage is seen causing you the error you are getting. best thing to do is take it to a repair shop and have them fix it or the manufacture should repair it for free because there is no fisical damage.
Posted on Jan 16, 2009
hsanfor
  • 71 Answers
SOURCE: Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
Posted on Jun 22, 2009
t00nz
  • 4738 Answers
SOURCE: CANON REBEL XT -CF card error
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, you may elect professional repair (likely more than you'd be willing to pay), or you might want to try the following.
Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jul 02, 2009
I having canon eos after i remove the memory card it says error cf or it says busy please help me
Hello
The issues you are running into are indicative of two possible issues.
First, the memory card may simply be bad. But before you purchase or try another memory card, you need to look for the second possible issue. The second issue, which is typcially more common, is that inside the card slot on the camera, there are pins, it is possible that one or more of these pins has become bent or damaged. If you look inside you can usually see a pin or pins out of alignment or bent over. If that is the case, the camera will need to go in for service.
Mar 12, 2011 | Canon Rebel XT / EOS 350D Digital Camera
My canon xt rebel says err cf and wont do anything i bought a new one an the same thing whats wrong
One of more of the CF pins inside your camera are bent over. This is very common. The solution is to remove the main circuit and replace the bent/broken pins. Most repair shops will charge between $150-$200 to fix this.
Wes
Sep 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My Canon EOS Rebel XT doesn't recognize the CF card. It recognized it earlier, but I removed it and now it won't see it. I also tried a different CF card and it didn't work.
LOOK INSIDE THE CAMERA Card SLOT AND SEE IF ALL THE PINS ARE STRAIGHT You may have bent the pins which is easy to do. If they are bent it will be a serviceman job to replace the module
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Is there something wrong with the camera when it states cf err
you could have a bad CF card or it may need formatted .. or you could have a bent pin in the CF connector in your camera .. that happens a lot if the CF card is put in wrong or if its poorly designed (not much lead in taper to capture pins) ... look in the card slot where you plug in your CF card .. look to see if any pins are missing or bent ..
Oct 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Jul 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Jun 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D CF memory card won't go into slot
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
May 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Sep 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
