Question about Dell OptiPlex GX260 PC Desktop
I need the circuit of the power using mosfets 52n03s
Pleases let me know from where i can get these spare parts for Dell Optiplex GX620 mosfets 52n03s
    Top Expert:
  • Dell Master
  • 3,698 Answers
Posted on May 11, 2014
bschilz
  • 2049 Answers
SOURCE: i have a dell optiplex gx620 and it wont turn on
As you can imagine, this is not simple thing to diagnose.
First, we need to try Dell's steps to fix...
Remove non-essential peripherals…
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one
  • Scanner
  • Printer
Try rebooting. If that doesn’t work, Dell states you need to do the next step.
Remove and Reseat Basic Hardware items:
  1. Power Cord
  2. Memory
  3. Hard Drive
At this point, Dells says if that fails contact them.
If my hunch is correct, you may have something on the motherboard shorting a connection or you have a blown capacitor. Get some “canned air” and blow out the computer thoroughly. Some people have reported the same symptom having dust or other debris causing the issue, so give it a good blowing out,
At the same time, inspect your motherboard thoroughly for an anomalies. If you see anything resembling the picture below, you have a serious motherboard problem which will require replacement.
Posted on Oct 20, 2009
yngwei50
  • 134 Answers
SOURCE: Adding network drivers to dell optiplex gx620
Just download the drivers here the link http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_PNT_P4_GX260
Posted on Dec 18, 2009
SOURCE: How to open the case
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtcvrop0.htm#wp1051283
Posted on Mar 08, 2010
  • 113 Answers
SOURCE: Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Posted on Jul 14, 2010
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
My dell GX620 desktop does not power when ever I plug in the network (RJ 45) cable. Also if the system has boots to desktop, and I plug in the network cable it automatically goes off.
1) Does it have a separate Ethernet Card, or is it integrated?
(Part of the motherboard)
Reasoning?
The Dell Optiplex GX620 comes with Integrated networking.
The chipset is a Broadcom 572.
It's part of the motherboard, and you plug the Ethernet Cable into the back of the computer.
However, you could have a separate Ethernet Card, plugged into the white PCI expansion slot on the motherboard.
http://www.ebay.com/itm/Dell-Optiplex-GX620-SFF-Motherboard-F8101-KH290-PY423-20-Available-/370743464509?pt=Motherboards&hash=item565208523d
A) If you are using a separate Ethernet Card, replace it.
B) If you are using the Intergrated networking of the motherboard, (Plug Ethernet cable into back of computer), use an Ethernet Card instead.
White PCI slot.
You have a short circuit when you plug the Ethernet Cable into the motherboard. Don't use the motherboard networking, use an Ethernet Card.
2) Plugging an Ethernet Cable into a computer that is on, = No.
It is not a Plug N' Play item.
(Not stating this is what you are doing.
Just posting in case you are. Burns out the Ethernet chipset on the motherboard)
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 20, 2013 | Dell OptiPlex GX620 PC Desktop
Floppy disket failure
shibukpza,
If your floppy disk has failed you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= to purchase one. You can also click the link below. If you do not use the floppy disk you can boot into the system bios by pressing the F2 key at boot up. Once in the bios you can disable the floppy controller.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 19, 2013 | Dell OptiPlex GX620 PC Desktop
Dell optiplex GX620 doesnt start
1-3-1 through 2-4-4
Memory not being properly identified or used
http://support.dell.com/support/edocs/systems/opgx620/en/ug/tools00.htm#wp1120374
Feb 12, 2013 | Dell OptiPlex GX620 PC Desktop
Install a new harddrivw on the optiplex gx620
Two wire are needed to attach a new hard drive.
Please refer to the links below ,to see how the attaching cables looks.
This cable is connects Hard drive to Motherboard
SATA Data Cable
This cable connects Hard drive to Power Supplier
SATA Power Cable
Jun 07, 2012 | Dell OptiPlex GX620 PC Desktop
Dell Optiplex GX620 Desktop PC's south bridge IC heats up abnormally...
Check the capacitors on the motherboard, Dell had a BIG problem with faulty capacitors on the GX270, GX520, GX620, GX745 and GX755 units. The parts would cause the unit to either not boot at all or lockup booting or running programs. I would bet you have some that are just beginning to fail and the motherboard power is not stable which would mean the chips are not getting enough power. Here is a link to an article about the issue and what to look for on your board.
http://www.ccl-la.com/blog/index.php/dell-optiplex-gx620-motherboard-repair/
I hope this helps you out, if so please rate my solution.
BuddyMc
Jun 30, 2011 | Dell OptiPlex GX620 PC Desktop
My dell optiplex gx620 keeps restarting it does not even enter bios plz help
Please see that the connectors on the PC, check if there is loose connect on the board. Also if the bios battery is low on voltage- check with a multimeter.
Finally the memory card can also have a loose connection on the slot, remove and reset or try with another card.
Apr 12, 2011 | Dell OptiPlex GX620 PC Desktop
I have four dell optiplex gx620 computers. Three
yes take it up to the place u bought form and say yall broke my stuff
Apr 15, 2010 | Dell OptiPlex GX620 PC Desktop
Dell optiplex gx620 is not switching on
Hi
Thank you for your query
The fault you are descrbing, sounds like a power fault please can you try thr following steps in order to resolve
1) Ensure that the fuse has not blown in the plug
2) Remove the 3 pin plug from the back of the PC, press and hold the power button in for approx 20 seconds (i know there is no power going to the PC), this is done to destat the PC
3)If the above fails then you most likely have blown the PSU on the PC
This will need to be repaired at a reputable PC Shop for replacement
Please leave positive feedback/vote if this has been useful
Feb 12, 2010 | Dell OptiPlex GX620 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
