Question about Health & Beauty
I have colour fade in my finger just after nail
How do I get the back off a Doogee X20L phone?
Back of my X20L is a diifferent colour (silver) to screen bexel (black). Slide thin object (eg finger nail) between back cover and bexel at top of phone. The whole back can then be removed
Sep 10, 2017 | Cell Phones
How do I paint my finger nails perfectly?
use cellotape or inch tape wrap around nails and color the nails and peel off simple and cheap
Feb 23, 2015 | Health & Beauty
Why is my printer printing faded colours
Hi Kath,
I expect you have it sorted by now.
I think you might have had one off the developer tanks stuck or broken. If the developer roller does not turn then the colour quickly fades along the page. If you tried to do a test page and that was good then there was nothing wrong with that side of things.
Good luck.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
Accoustics solutions 37 inch tv colour fading and changing
Increase the color saturation to fight the fading and decrease brightness slightly. All of these settings are in the menu of the TV.
Jun 07, 2012 | Televison & Video
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
HP Z6100- Magenta ink density fade
there may be air bubble in ink tube assembly if u can do the priming then ok o/w call hp service provider to do this
Jul 28, 2010 | HP Designjet Z6100 InkJet Printer
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Old Polaroid photos
Having photographic quality copy prints made will give you far longer life than the original Polaroid. Polaroid colour dyes will shift colours and eventually fade dramatically. New photographic (and some ink jet) prints will last generations without noticeable fading.
Feb 24, 2008 | Photography
Health & Beauty Logo
71 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
