Question about Konica Minolta Copier Toner 7033/7040 900gm 950-414
ERROR CODE F-46-8 IN MY COPIER - Konica Minolta Copier Toner 7033/7040 900gm 950-414
  • 53 Answers
I think you need to replace the front door interlock switch ( very common part ), and then take some time and adjust the bracket for a really good positve closure on the switch....leave the display panel off during this adjustment so you can get a good look at the switch closure. There is no factory adjustment on the bracket- you might have to bend part of the bracket to get a good closure. Open and close the front door a couple of times just to be sure and there you go. This front door interlock switch is a common failure on the 7033, 7040, and 7045's and will give you all kinds of crazy symptoms.
Posted on May 26, 2014
MACHINE ERROR 46
Hi
This code indicates that the internal ink absorber box is full and requires replacement I have included a link below that explanes what you need to do to fix this
MFC 215 error 46
Aug 02, 2014 | Brother Office Equipment & Supplies
Hp z6100 plotter error code 46:03
System Error:
46:03
Problem Description:
Primer servo shutdown.
Corrective Action:
Try the following:
1. Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2. Replace the Primer Assembly .
3. Replace the PrintMech PCA .
4. Replace the Interconnect PCA .
Feb 06, 2013 | HP Designjet Z6100 InkJet Printer
Troubleshot 46 on mfc-240c
Error code 46 means that your ink absorber pad needs to be replaced. According to Brother, only an engineer can do that, but you can get more information from them by contacting Brother support:
http://www.brother-usa.com/Support/
Click on "Send us an Email" and tell them your printer's model number, the error code, and whether or not your machine is covered by a warranty.
Jun 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
Unable to clean refer to maintenance guide 46
Hi
Thanks for using FixYa. Printer error 46 indicates that the ink absorber pad is full and required to be replaced by an authorized engineer. To resolve the issue please contact Brother Customer Service from "Contact Us" on their website—
Error 46 solution
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
Fax Recive Error on sharp MX2300-N "receive impossible"
Communication report codes
46 NO RESPONSE The FAX signal from the remote party is not detected within T1 time. <Send/Polling>
Feb 04, 2009 | Sharp MX-2300N Color Copier
Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
Konica Minolta Copier Toner 7033/7040 900gm 950-414 Logo
90 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
