Question about Home
Grohe sink handles
No screws came with the handles
    Top Expert:
  • 3,698 Answers
Take it back ort have the seller send for them for you.
Option two ; Take a stem and handle to the hardware store and match it up.
Posted on May 11, 2014
How to remove handle on single handle grohe shower valve. no screws on handle
There should be set screw on bottom of handle it very small it's a Allen wrench set screw
Jun 12, 2016 | Grohe Home
I can not get the handles off. there are no screws
There is either a screw under a cap from the top or a set screw from the side. Looked at about 200 Grohe diagrams and they all have that arrangement.
Aug 07, 2012 | Grohe Seabury Widespread Lavatory Faucet...
I can not figure out how to get teh handle off !!!...allen wrrench?
should have allen screw under the red and blue tab under handle just pry off with drywall knife..tab should just be held w/ o ring...if that doesnt work maybe the whole assembly screw off rite below the handle
Nov 27, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I can not take the handle off of my shower valve to get to the cartridge. i have a seabury grohe shower valve.
There is usually a set screw near the base of the handle that holds the handle on the valve stem if the handle is metal. if it is acrylic then there is a plastic cover that hides a screw which fastens it to the valve stem.
Nov 24, 2010 | Grohe Plumbing
Slow leak from water line
I think you will only need a basin wrench. If I'm understanding you correctly, you want to tighten the water supply lines? If you've never used one before, ask the guy at the hardware store to demonstrate how to use the basin wrench.
Jun 15, 2010 | Grohe Chiara Neu Lavatory Centerset ...
Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Feb 15, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
The black coating on the handle of our grohe kitchen faucet was chipping so Grohe sent us a new handle. We have tried all sorts of muscle power and tools and simply cannot get the old one to come off. Is...
Is there a little emblem or similar in center of handle that pops out to expose a screw or allen key style screw? Also check around base of handle,(almost standing on your head) for a n allen screw head as well, or any area that looks like it might pop out .
Dec 31, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Jan 19, 2009 | Plumbing
All of a sudden can not get hot water from my Grohe Ladylux plus
I aasume this is single handle
You will need to remove the handle(usually hex screw under lever or bak side covered with small erasure size button
turn water (hot and cold) off under sink
remove the handle
take an adjustible wrench and remove the cartridge it is keyed
so ou can put it back roperly inspect the cartridge for any obstructions
go under sink and slowly turn hot water on and observe if water is coming out of faucet manifold
if water is coming out ok you may have a bad cartridge or had a blockage reinstall cartridge(after youturned water off
turn hot and cold water on under sink and try again
if it works great if not I suggest you take artridge out and replace
Dec 29, 2008 | Plumbing
Grohe Bathroom Faucet
If you don,t see any set screw for the handle, ( sometimes it is hidden under a small access cover top of the handle) Then the handle is threaded on where the base of the handle meets the sink/countertop surface. It is a right hand thread and will take a few turn before it comes off accessing the faucet stem.
Good Luck, Phil
Nov 05, 2008 | Plumbing
Home Logo
41 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
