Question about Sony Alpha DSLR-A100 Digital Camera
How do you straighten the contact pins to read the card?
    Sergeant:
  • 308 Answers
I would make sure it's the contact pins by trying a different card. We've had one of our A100's for a long time and has seen much use without any problems. Make sure the contacts on the card itself is not tarnished or dirty also. If the pins are at fault, they would likely need replacing and that's when I'd look into an A-58, 65 or 77 upgrade.
Posted on May 11, 2014
My psp slim 2000 can't read the memory card
The pins inside the memory card slot are probably twisted, you have to straighten them up.
Dec 23, 2010 | Sony PlayStation Portable (PSP) Slim...
Xsi rebel will not read or reformat memory card
You need to have a look at the slot where the memory card goes in. Using a light, look down in the slot at the pins the match up to the card. There may be one or more bent or broken. If the pins are damaged, then it would be a major repair. Usually once they have bent, trying to straighten them back causes them to break off.
Jan 16, 2010 | Cameras
Have err CF. Notice that at least one pin is bent where the memory card is inserted.
That is the problem. The card will not fit in and if you use force, you may damage the terminal beyond repair. You can carefully try to straighten the pin(s), but if you don't feel comfortable to do it yourself, take the camera to the shop.
Nov 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel xti Error message "can't read card or card corrupted". I have tried 4 new cards, same result. What next?
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jun 09, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Memory card error
Dec 29, 2008 | Canon PowerShot A75 Digital Camera
I have a compaq presario sr1230nx and when i go to put in a ad card the light next to the slot blinks green and then the card cant be read. then the explorer crashes for about 20 seconds and then i tried...
The memory card reader on your computer may not be able to read memory cards over certain capacities (4 GB).
To use your higher capacity memory card without locking up the computer, do one of the following:
  • If you are using the card in a camera or other device, you can attach the device to the computer using a USB or FireWire cable. When connected, most devices appear in Windows as a Removable Disk and can be used in the same way as the card reader.
  • Purchase a USB memory card reading device that plugs into any open USB port. Make sure the USB device is capable of reading SDHC. These devices are fairly inexpensive and can be used in any computer that has a USB port.
If the card reader stops working after using Safely Remove Hardware, reset the cable connections and memory card firmware.
Memory card appears in My Computer but errors occur when writing or reading
If you are having problems reading and writing data to memory cards, use the following troubleshooting tips:
  1. Try a different memory card of the same type in the same slot. If the different memory card works, the card reader is good and the original memory card should be replaced.
  2. Some cards have a read/write security switch on the card. Make sure that switch is set to Write Enabled before attempting to write data to it.
  3. Make sure that the amount of data you attempted to store has not exceeded the capacity of the card.
  4. Inspect the ends of the memory cards for dirt or material closing a hole or spoiling a metal contact. Clean the contacts with a lint-free cloth and small amounts of isopropyl alcohol. Replace the memory card if necessary.
  5. Make sure the memory card is one of the supported types: CompactFlash (1, 2, and Microdrive), Memory Stick, MultiMedia, Secure Digital, or SmartMedia memory cards.
  6. Make sure the memory card is fully inserted into the slot.
    Remove the memory card when the light is not flashing and shine a light into the empty slot. Are any small pins inside bent? Replace the memory card reader or have the computer serviced if a pin is touching another pin. Straighten slightly bent pins while the computer is off using the tip of a mechanical pencil.
  7. If errors persist replace the memory card.
Dec 20, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Not working
Try a different memory card. Some of these cameras may not support large sizes. Try a smaller card such as a 512 or a 128.
Aug 08, 2008 | Canon PowerShot A80 Digital Camera
Card wont read
The pin is bent on the camera? This unit card reader in the camera needs to be replace or maybe the card is uncompatible for the camera. it sould be and sx or sd card for a camera.
Nov 22, 2007 | Nikon Coolpix 2100 Digital Camera
Compactflash memory cards
If it will not read ANY type of flash media it would suggest the reader or main board is faulty.
If it reads some type but not others, look down into the card slots with a torch and check to see if any of the pins are bent over. This is a common fault most notably encountered when the machine fails to read CF type cards. You will see two rows of pins in the slot. Chances are one of the pins is bent or been pushed inwards. If you are REALLY steady with your hands you can use a very small (jewelers) screwdriver to straighten the pin. If the pin has receded, it almost impossible to fix it.
Aug 18, 2007 | Epson Stylus Photo R320 InkJet Printer
Granddaughter forced memory card into slot incorrectly and bent pins
A long pair of needlenose pliers, or possibly tweezers. As you've noticed, it's near impossible to disassemble the needles from the mem card housing.
Jul 27, 2007 | Canon PowerShot S30 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
