Question about Electric Air Pump
Where can I get an AirPedic Pump Model XX/FCAC2/001
Model XX/FCAC2/001
2 Suggested Answers
SOURCE: need electric motor for dual control air pump
I have the same problem with a Simmons Airpedic bed system. Same model #xx/fcwt2/001. We found this number on the motor 800 247-0677. They want $250 for a king size. Have you come up with anything?
Posted on Aug 31, 2010
Need to hook up wire for the element in the kettle of my GR6A1X -XX -X
Here is the wiring diagram for that model. Black(hot) wire to empty side of thermostat, red(indicator lamp) wire is doubled to the wire that goes to heat element, and the white wire is attached to far end of heat element.
Dec 13, 2012 | Cretors Goldrush Popcorn Maker
Hi, I have a problem. I wanted to filter the
The address you wrote is not a MAC address, it's an IP address. The MAC address is the physical network card address.
A MAC address has a form xx:xx:xx:xx:xx:xx, or as Microsoft likes it, xx-xx-xx-xx-xx-xx, where xx is a pair of hexadecimal digits (from 0 to F).
You can find out your cards' MAC addresses either by inspecting the card hardware, where often it's written on a label, or using "ipconfig /all" command (from the command prompt) - it will show you the physical addresses of all the installed network adapters.
If you have locked yourself out completely from your router and cannot access it's configuration page, you will have to reset it to factory default settings (see manual on how to do that) and re-configure it from scratch.
Oct 28, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Need electric motor for dual control air pump
Sep 23, 2009 | Electric Air Pump
I am trying to secure my router with password but
would you mind providing make and model of router? You can connect to the router with ethernet cable and look at your Gateway IP address. Take that ip address and type into your browser as http://XX.XX.XX.XX Where the XX's are your gateway ip address. this will get you to your routers config page. From there you can try the default password for the router then go on the actually configuration. But its hard to direct further without know specific make and model.
Sep 22, 2009 | Belkin Computers & Internet
I decided to switch to ubuntu 9.04 os but i have problem with dial-up connection using Dlink 562is modem.
1. Install hsfmodem_7.60.00.09full_i386.deb from terminal
* type sudo dpkg -i *.deb
* Where is the linux source build directory that matches your running kernel?
* [/lib/modules/2.6.20-15-generic/build] press Enter
* Please enter region name for modem unit 0 [XXX] : type country name then press enter
* Please enter your email address [unknown] : type your email address then press enter
* Recorded The registration ID for modem unit 0 is: XXXX-XXXX-XXXX
* Please enter license key [FREE] :
2. Open new terminal, type ./genertor.pl [email address] [Registration ID]
3. get key: XX-XX-XX-XX-XX-XX
4. enter the key on Please enter license key [FREE] :
5. Copy hsfpatch to /usr/lib/hsfmodem :
* $ sudo cp hsfpatch /usr/lib/hsfmodem/
6. Execute patch file : $ sudo ./hsfpatch
* file 'modules/imported/hsfengine-i386.O' openend
* patching... done
7. Reconfigere hsfmodem : type sudo hsfconfig
* Press ENTER for all the questions
* Would you like to keep using them? [no]
* Please enter region name for modem unit 0 [XXX]:
* Please enter your email address [XXX@XXX.com]:Please enter
* license key [XX-XX-XX-XX-XX-XX]:
8. Reconfigure hsfmodem complete :
* Config for modem unit 0: /dev/ttySHSF0
* Device instance: 0-PCI-14f1:2f30-14f1:20d5
* HW revision : Basic2 2.18 Standard DAA 3VoltsIA
* HW profile name: hsfpcibasic2hsfi
* Registration ID: XXXX-XXXX-XXXX
* License owner : XXX@XXX.com
* License key : XX-XX-XX-XX-XX-XX
* License status : OK
* Current region : XXX (T.35 code: 0054)
* The /dev/modem alias (symlink) points to ttySHSF0
9. Install KPPP
10. Browse The World
Jun 17, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
I have a belkin router asdl wireless how to secure the connection
The easiest way is to turn on the mac restriction feature and only allow the macs from the machines that you want to have access.
Since I didn't see the model of router listed, you will need to refer to the manual for exact instructions on enabling that feature.
You can get the mac addresses from the machines that you want to have access to the router in xp by click Start > Run > type cmd.exe and press enter. Then type ipconfig /all and look for the physical address of your adapter. It should be in the format of XX-XX-XX-XX-XX-XX. Once you get that information you can allow it in your router.
This will give you basic security on your router.
Thanks
Aug 09, 2008 | Belkin Computers & Internet
Trying to remove a ip route on the 5871.
normally on router commands, in order to delete something you do not write del, but instead write out the command you would type to add the route with the word no in front of the line.
so if the command to add was eth ip addroute xx.xx.xx.xx xxx.xxx.xxx.xxx xxx.xx.xx.xx 1
the command to take it off would be, no eth ip delroute xx.xx.xx.xx xxx.xxx.xxx.xxx xxx.xx.xx.xx 1
May 09, 2008 | Efficient Networks SpeedStream 5871 Router
CODE REGION
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Mar 17, 2008 | RCA DRC247N DVD Player
NEDD TO KNOW HOW TO WORK THE FADE CONTROL
Press the <<,>> button and select "Fader".
Turning the Rotary knob clockwise fades the sound to the front; turning the knob counterclockwise fades the sound to the rear speakers.
The display changes as follows:"Front XX" will be displayed where "XX" is the value from 1 to 12.
"Rear XX" will be displayed where the "XX" is the value from 1 to 12.
When fader is 0, "CENTER" will be displayed.
Jan 04, 2008 | Clarion DB175MP CD Player
Electric Air Pump Logo
22 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
