Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Why is Hunter thermostat temp is wrong ? - Hunter Fan Company 5/1/1 Programmable Thermostat
    New Friend:
The most likely problem is the wall on which the thermostat is mounted. The thermostat is designed to read the temperature of the space in the room, but if the wall is exceptionally warm or cold it can really throw off the actual reading.
Options might be to stuff insulation into the wall behind the thermostat, or relocate it to a wall that is more consistent in temperature with the actual temperature in the room.
Posted on May 11, 2014
Hunter 44665
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
Nov 22, 2013 | Hunter Fan Company 5/1/1 Programmable...
Programming the remote sensor to the 44665 hunter thermostat
Just fixed mine;
Note the sensor channel on face of remote
(ref: http://www.manualslib.com/manual/257219/Hunter-44665.html)
Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7.
Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp.
Note the button order for Remote Sensor Programming at base thermostat:
http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
Feb 05, 2012 | Hunter Fan Company 5/1/1 Programmable...
My thermostat defalts to 60degrees on weekend right about eight in the morning. it raise it back up but at 10:00 pm it defalts back to 60. Ihave it set for a daily temp at 68. works fine during the week.
You didn't indicate the model # but it sounds like it is defaulting to factory program 2 on the weekend. For information on operating and programming visit Hunter Thermostat Manuals and enter your model # to view and download the manual.
Feb 06, 2011 | Hunter Fan Company 5/1/1 Programmable...
I set temp to 74 and stop at 70 and decresing.
Sounds like the variances are not set right. if I am understand you. You set the thermostat to 74 and the heater shuts off at 70? If that is correct then the variances are wrong or you have placed the T stat in a bad location where it is getting heat from a vent, wall where there is a appliance or in a very drafty location
Feb 10, 2009 | Hunter Fan Company 5/1/1 Programmable...
I have a hunter 44150B thermostat and when i replaced the batteries, the temp is in celcius instead of ferenheit...HELP!
Pull the whole thing off the wall there is a switch on the back marked F and C. Make sure the switch is set correctly.
Feb 02, 2009 | Hunter Fan Company 5/1/1 Programmable...
How do you set the thermostat??
hi
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
riz.
Feb 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
108 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
