Question about GE JVM2070 Microwave Oven
Why is my microwave turntable not spinning and therefor not heating?
    New Friend:
  • 153 Answers
Change ur megnatron may b solved ur problem
Posted on May 11, 2014
Kenmore microwave 72169122010 turns on but wont heat or spin turntable?
Door sw 'turn on and push up and down on the door it make come on
Oct 15, 2014 | Microwave Ovens
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Getting sparks when in use Whirlpool GT4185SKB. This was made in 2003. What is the problem? If not possible to repair, is it still available new? Thanks.
If your microwave has a turntable its probably just burnt food inside or above the oven chamber that has carbonized. If it doesn't have a turntable its possible the stirrer above the oven chamber is stuck and not moving the microwaves around, therefore causing over heating and arcing. It also could be that the stirrer blades are hitting inside. Hope this helps
Feb 21, 2010 | Whirlpool GT4185SK Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
GE Built-in Microwave (JE1540w002) NO Heat and turntable not moving.
locate the diagram and check you monitor switch it is one of your door switches
Feb 15, 2008 | GE JE1540 Microwave Oven
GE JVM2070 Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
