Question about RCA RT2300 System
I have a RCA RT2870A that i need a manual or help hook it up to TV and DCD
    President:
  • RCA Master
  • 1,114 Answers
This is the manual for the 2770 from RCA.com http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
If it has the same inputs as yours, you need an "optical" cable that will go from the TV "output" to the RCA system "optical input" and a "Coaxial Digital" cable from your DVD player to the "Coaxial Digital input of the receiver. Not knowing what kind of TV you are hooking this up to... If it's and LCD,Plasma, or Digital TV, it will have an optical audio out. if it's not one of these, post the model number of your TV & I'll check it. If you are using Cable TV/Satellite or FIOS, Great! then you can run the optical cable from the back of the cable box to the receiver. If you need any more help, just post a comment and I can help you some more.
Posted on Jun 23, 2009
On my RCA TV we can't find a way to hook up our PlayStation 2 to the tv
if your model is too old , you will not find it. however download your instruc. manual from www.fitness.manualsonline.com or www. retrevo.com and looking for the instruction.
God bless you
Jul 12, 2012 | RCA TruFlat 27F520T 27" TV
Can not figure out how to hook the rca system to the tv and satellite receiver,he either gets a picture or sound, can't get both. the user manual we had is very worn and can not be read anymore. can...
The all time best way to hook up the system would be, depending on TV's input output connections, would be hook the satellite receiver directly to TV input, best being HDMI, second being component video(in this case you would use separate audio cable(s), either digital optical, or RCA. Then provide audio out from TV to reciever using digital optical or RCA. You can try to pass video through the reciever however, it is not your best route and you may get a lag between video and audio. Make and model numbers would help in this situation.
Jun 04, 2011 | RCA Audio Players & Recorders
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
I have recently been given a XD DCD LG Plasma TV and do not have instructions. I cannot tune my DVD/Video player into the TV - Can you send me...
USE RCA CABLE SET IT IS YELLOW/RED/WHITE THE YELLOW SHOULD BE VIDEO IT WILL SHOW THIS ON SET AND PLAYER. I WOULD ALSO RECOMMEND YOU USE THE AUXILIARY PLUG IN ON SET THEN JUST TURN ON SET AND SET TO AUXILIARY IF YOU DON'T HAVE THIS USE DVD FEED IN THEY SHOULD BOTH HAVE RCA PLUG INS FOR RCA CABLE
Jul 09, 2009 | LG 50PC1DRA 50 in. Plasma Television
My rca tv
The remote control may only work for the cable box and you may have to manually put the TV on the correct input channel also you might double check that the cable to the TV is hooked to the antenna input. Here is the website for the manual TV if you think it might help.
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Sep 05, 2008 | RCA TruFlat 27F520T 27" TV
JVC DCD Recorder hookup to digital TV
Yep, this recorder is NTSC analog. Sad, too - it was only manufactured in 2006 - they knew about the digital transition then. There is a possible workaround, but it depends on your TV - if your TV has a red, white AND (most importantly) yellow OUT/OUTPUT, then you can hook it to the AV IN on the back of the JVC and record from TV that way. Note: most TV's (even new ones) do not have the yellow video/monitor OUT, even if they have red and white audio OUT's.
-Tha Mp3 Doctor
Sep 03, 2008 | JVC DR-MV7 DVD Recorder/VCR
Need a Manual or help with System
YOU NEED TO HOOK YOUR RCA CABLES FROM YOUR DVD,TV,AND DIGITAL CABLE TO THE INPUT SIDE OF THE SURROUND. HOOK THE RCA CABLES FROM THE TV TO THE AUX SIDE AND THE DVD TO THE VCR INPUT, AND THE DIGITAL TO TH LD SIDE OF THE INPUT YOU CAN SWITCH BETWEEN THE 3 ON THE FRONT OF THE SURROUND.BY MOVING THE KNOB. YOU WILL GET NOISE FROM THEM THEN TO THE SPEAKERS.
May 24, 2008 | Emerson HT200 System
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Dvd recorder, pc, dcd player
I take it this is a recorder only model not one with hard drive. I guess it will be line out from PC to line in on the recorder The recorder probably has RCA red/white cords So you will need a 3.5mm stereo jack to RCA converter this will work on the PC either way line out for trans to DVD line in for form DVD to PC
Jun 23, 2007 | Sanyo DRW-500 DVD Recorder
How to hook up a DVD player
Go to this link; http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Mar 29, 2007 | RCA F32450 32" TV
RCA RT2300 System Logo
1,154 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
