Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
How to troubleshoot swing motor problems on a 1963 jd row cropper backhoe?
I lost the ability to swing my boom on my 1963 john deere 2010 row cropper backhoe how do i fix it
  • John Deere Master
  • 2,760 Answers
Just like any hydraulic system there is A (IN) and a (OUT) on every cylinder and motor on tractor (even steering) loosten (NOT remove) the hose fitting thats on (A or In) to motor and attempt to move joint/device with controls if a steady drip of fluid is present then your problem is device (cylinder,motor) if no drip then follow hose up to power divider or solinoid or hand valve and attempt same procedure , keep moving up the line till you get a steady drip of fluid and last device in liine is the problem device , repair or replace it
ALLWAYS turn off motor and release pressure from hyd system before you attempt to completly remove any device from system for replacement , and note that booms and arms and heavy stuff will relax(fall) with no pressure in system , prepare for this to happen (blocking,chaining)
Posted on May 17, 2014
SOURCE: 2010 distrubuter problems
The timing gear is made from material which will break if the gears are not meshed correctly, if the distrubiter has come loose at some time, this can chew out the timing gear and leads to all sorts of problems (ie correct timing)
Posted on Feb 12, 2009
  • 246 Answers
SOURCE: My fuse keeps blowing on my neutral safty switch
Hello williamhowar:
>>As I am Sure you are Aware, Most Backhoes do a Lot of Bouncing and Jarring. LOL.
>>If you can Trace the Harness, then Check of a Bare Wire that is May be Touching the Unit.
>>If the Harness is Good, then I will Require some More Information about this Unit in Order to Assist you Further.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Thanks.
Respectfully
jbridger (John)
Posted on May 14, 2009
jdlipscomb41
  • 157 Answers
SOURCE: my father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
Posted on Sep 18, 2009
  • 78 Answers
SOURCE: 1963 jd 2010 manual calls for 10-30 motor oil. I
If thats what the manual calls for thats What JD meant to be used in it
Posted on Oct 22, 2009
miket756
  • 2702 Answers
SOURCE: John Deere 210 C backhoe loader - quesion on hydraulic fluid
yep there is!
Posted on Jul 13, 2010
What year is the following john deere backhoe 310G :t0310gx911769
You just go to the link I attached I'm sure you will get the solution of your problem.
Apr 25, 2017 | John Deere Garden
John deere capacities
Repair your vehicle right away. Just click on the link I attach.
Best Manuals
Apr 18, 2017 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
I have a john Deere 310sg backhoe that is showing a f-428 service code and also have an issue with the park brakes continuesly setting is this a simple fix. The computer was recently replaced
f-428 means the foot throttle pedal sensor is not calbrated
the software that's in the computer , this makes sense since u replaced the computer recently , to fix this its gonna require the JD tuning tool interface and software 4 it
I suspect the park brakes issue is sort of coming from a similar conflict in sensors on the transaxle or something
gone is the days that a new computer would self adjust its self when 1st installed , in fact if you read your owners book JD requires a yearly software update now
Apr 03, 2015 | John Deere Garden
I have a 310SG john Deere backhoe and it loses power in 3rd and 4th gear on a hill I need help please.
I'm having the same problem with my jd 310. Did you ever end up finding a solution?
Dec 19, 2012 | Cars & Trucks
Need diagram to take off and repair F115 John Deere Riding Mower
Type in engine repair manual 115 jd b&s on Goggle.
Jun 25, 2012 | John Deere Garden
I'm looking for a manual on a John Deere 2010 backhoe attachment, model 7000, serial number 2930.
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet
Dec 06, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I NEED INJECTOR PUMP SCHEMATIC FOR JD 400 PUMP
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
77 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
