Question about GE GFSS6KKYSS
Why is back panel in fridge freezing up?
Behind back panel of refridgerator is freezing up
    Sergeant:
  • 308 Answers
Generally, I'd suspect the defrost timer being stuck or broken.
Posted on May 11, 2014
2 Suggested Answers
  • 2468 Answers
SOURCE: ge side by side ref.
no,its more than likely the defrost heater located just under the coil thats freezing up,check this heater for continuity,if its o.k. then test the defrost thermostat thats clipped onto the same coil near the top of the coil,note,the defrost thermostat needs to be below 15 degrees to check good as its a thermal switch,then if still problems then check the main board in the back of the unit behind a panel this is where the defrost circuit gets its power,but i will likely say its the heater thats open because i replace about 5 per week with the same issue as yours
Posted on May 23, 2012
Where is the evaporator on a kenmore 106.8607913 refridgerator
Hello, Thank You for using FixYa. I will be helping you today. The evaporator is behind the panel in the freezer section. Its the big aluminum thing behind the panel.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Kenmore Refrigerators
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
The refridgerator is not getting cold
sometimes when the air flow is restricted cold air migrates back into the bottom of the fresh food side and could freeze the dispenser resevoir which is behind the crisper drawers. Also, just defrosting the freezer is only treating the symptom. Something malfunctione to allow the frost to build up. Either the heater, defrost limiter or defrost timer.
May 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Fridge not cooling
In the freezer compartment on the back wall there is a panel , behind that panel is the evaporator coil and return air ducts that go up to the fridge.
these ducts freeze up, thus not allowing the cold air to circulate to the refridgerator. You can unplug the unit overnight and let it defrost on its own, or you can help it using a blowdryer for a couple of hours. just lay the blowdryer in the freezer area with the doors open and let it defrost.be sure to place an old towel on the bottom to catch the water.
Jan 16, 2010 | Zanussi ZI918 / 12K Bottom Freezer...
Refridgerator is only cold on the bottom. Fridge is a side by side and both sides are doing the same thing. Top shelves are not cold or freezing, but the bottom ones are. What is causing this?
Good day,
The common reason for this is the fan motor behind the rear panel in the freezer compartment is not running.
With the machine on and running, open the freezer door. You should hear the fan running.
If not the motor can be accessed by removing the rear panel in the freezer compartment.
Replacement is a nuts and bolts operation.
Dec 17, 2009 | Refrigerators
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Fridge not cooling
unplug unit and let sit overnight to defrost,
Oct 29, 2009 | Refrigerators
My refridgerator is not keeping cold any more? what is the problem? The model is Ge GSS22WG. it does not freeze or keep things cold, all of my food went bad. I need help I dont have the money to buy a new...
it could be an air flow problem. Pull the unit out, unplug it. Clean out any dust, dirt, or anything else you see in there. Also when you push it back in make sure you have a few inches clearance behind and to each side of unit . Good Luck.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
For the second time this year my fridg is quit working. I is only about 7 years old. It is not cooling on either side. The ice maker is not freezing the ice very well it ends up freezing in lumps that we...
Check behind the fridge where the compressor is and see if the condensor fan is working,also clean all the dust out of the fan area eg condensor. Hope this helps Kind Regards.
Jul 09, 2009 | Kenmore 57029 Side by Side Refrigerator
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GE GFSS6KKYSS Logo
513 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
