Question about Car Audio & Video
Infinity Reference 5760a amplifier. The problem is definitely in the amplifier (I've switched inputs and outputs to locate the problem). The front right output will intermittently go from normal to low to no output. Most of the time, it has little or no output. I'm not scared of electronics, so if someone could point me in the right direction as to what to look at inside the amp, I'd appreciate it. I am the original owner and have only used to push Infinity Kappa and Reference speakers.
techman
  • 3130 Answers
SOURCE: amp install disaster...?
Try first to disconnect all of the speakers on the amp. See if the amp will turn on now. If not , the amp has bad output devices, or drivers, and or the switch mode power supply is fried. There is no easy fix with solid state elctronics as there are no user serviceable parts inside. The units going to need to be repaired by a service tech unless you know how to solder, unsolder, test mosfets, transistors, and diodes as well as resistor.
Posted on Sep 22, 2006
SOURCE: amplifier not working
i agree put in a repair shop or send it back to manufacturer
Posted on May 06, 2007
trintek
  • 111 Answers
SOURCE: Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Posted on Nov 17, 2007
SOURCE: JENSEN XA 184 AMPLIFIER
Looking at amp pin no.1 (top row on left, closest to the GND terminal) from left to right
{ output } { input }
[FL-] [FR-] [RL-] [RR-] [FL-] [FR-] [RL-] [RR-]
[FL+][FR+][RL+][RR+][FL+][FR+]{RL+][RR+]
Posted on Nov 20, 2007
  • 12 Answers
SOURCE: Eclipse PA5532
I do think you can knowing your Amp is 5channel and 960watts,Yes you can goto radio shack for the potentimeter or goto your local audio store and buy a equalizer So you don't over power your Amp
Posted on Nov 22, 2007
Infinity tss 750 sub-woofer when powered on immediately pulls speaker in and has loud humming. no inputs hooked up, only plugged in to ac power source.
The loud humming is the sound of AC mains - clearly your amplifier is receiving an input from somewhere and possibly into the front end.
The hum could be induced by radiated energy from nearby unshielded equipment, it could be the result of an accidental hum-loop or could be because the amplifier power supply has a fault.
It is usual practice with amplifier construction to ensure unused inputs are shorted to ground by switching or by additional contacts and wiring at the input sockets. High gain high impedance inputs can cause a great deal of unwanted noise if they are not shorted.
I suggest you read the instruction manual and perhaps Google a few hints and tips about amplifiers and stuff.
Mar 28, 2016 | Infinity Audio Players & Recorders
Infinity 1300a car amp won't turn off...
The possible area is definitely in the stanby switching circuit. A damage to the relay drive has made the power to be continuously on without the remote switch. You can have two solutions, one you can ignore the fault for the time being and connect a second relay fromt the system to trigger the relay and subsequently switch the amplifier main power. Or you must open the set and look in the remote switching area for a jammed relay, a faulty transistor drive or activation of the bias to the relay drive by a faulty component. Check this out with a good multimeter and you will solve the issue. I hope my advice helps. Good day
Jul 22, 2010 | Infinity Reference 1300a Car Audio...
Amp 7541a amp was working fine, Took it out of one
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. KEEP IN MIND, THAT DURING THE INITIAL TURN ON OF THE AMPLIFIER, THEY SOMETIMES WILL ILLUMINATE THE PROTECTION LIGHT WHILE STABILIZING THE POWER SUPPLY AND OUTPUTS, BUT AFTER THAT THEY SHOULD SHOW NORMAL POWER UP. IF YOU GET IT TO POWER UP FINE, THEN RECONNECT THE SPEAKERS AND IF STILL OK, THE RECONNECT THE RCA'S. IF IT IS STILL POWERED UP, THEN START TO TURN UP THE MUSIC. IF IT IS STILL POWERED UP AND NO MUSIC, THEN CHECK THAT YOU DEFINITELY HAVE A PROPER SIGNAL COMING FROM THE RADIO. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 18, 2009 | Infinity Reference 7541a Car Audio...
Is there an in-line amplifier for the speakers in a 96 jeep grand cherokee limited w/ infinity gold audio system
Yes, the Infinity Gold series audio systems have a separate amplifier. In my '97 the amplifier is located under the drivers side rear seat.
Note that the amplifier is set to have speaker level inputs as opposed to regular level inputs. Both the amplifier and the speakers are NOT easily mixed and matched with after market components.
Nov 13, 2009 | 1996 Jeep Grand Cherokee
Where is the amplifier for the stereo?
Amplifier: Locations
Fig.12 Midline/Infinity Remote Amplifier Location
Midline And Infinity amplifier is located in the right front Cowl panel.
Infinity II amplifier is located beneath the trunk liner covering the right quarter inner panel.
Sep 11, 2009 | 2001 Chrysler LHS
I have an Infinity 530a 5 channel amp. new
May be the problem is on the sound you are using is not a 5 channel coded sound or check in the menu´s of the amp if the rear channel´s have sufficient db output, check the connections, check if you amp. is not working only as simple stereo (menus also)
Hope this helps
Jun 24, 2009 | Infinity Car Audio & Video
Infinity Reference 7541a protect & Clip lights come on
Hello pianopeter, I have the same amp with the same problem but only when the crossover mode switch on the front channel is set to low pass or high pass. Have'nt fixed that yet cause when I got the amp and put power to it the clip and protect lights would flash back and forth. I turned out to have 2 bad output transistors on the right front channel, I replaced them and amp works great now. Then when I was doing final testing I switched the crossover mode switch to lowpass and your problem occured. I do believe the problem is in the removable board which controls the controls the crossover and input to a point. Try moving the crossover mode switch to flat on both front and rear and let me know if amp works fine that way. I'll be working on this problem soon but would like to know if your problem changes if you move the switch to flat. Please leave me a message as soon as you find out cause this will aid in the process of me fixing problem. I am an electronics tech and buy and fix broken amps all the time so I have a really good knowledge of car amp repair. Once again let me know ASAP, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Jan 15, 2009 | Infinity Reference 7541a Car Audio...
Can you help me with Infinity REF-5760A
ok positve on amp straight to battery
negitive to ground on car or battery
remote wire to back of head unit
and rcas in head unit to amp
Sep 04, 2008 | Infinity 7540A Car Audio Amplifier
Blown channel?
your amp try to protect itself from damage when he feels some trouble from your sub.-start by changing sub cabel and sub itself if it does not becomes ok.
if all above failed---you have serious problem in sub output stage and can be fixed in service center.
Oct 17, 2007 | Audio Players & Recorders
Amp install disaster...?
Sep 22, 2006 | Infinity Reference 7541a Car Audio...
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
