Question about Sears Garden
I have a honda 3813 riding mower. When i try to start it,it backfires a litttle but will not run.?
    Top Expert:
  • Sears Master
  • 3,698 Answers
Backfire usually means that it is out of time. This sometimes happens when something is hit causing the flywheel to jerk shearing the flywheel key. Remove flywheel and replace woodriff or slot key.
Posted on May 11, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Be sure the fuel is fresh. This spring I had two pops and no start. The "gasohol" was not treated and 4 months old. Purging old fuel fixed it!
Posted on May 15, 2014
  • John Ehrhardt May 15, 2014
    Gasohol or too much fuel cleaner can also cause loss of power.
  • John Ehrhardt Apr 23, 2017
    Update - Replaced the fuel pump. Starting is one again prompt. The old pump (5yr) was providing pressure however priming the line by pressuring the fuel tank (blow on the vent tube), I noticed the forward resistance was low and starting was improved when using this procedure.
  • 71 Answers
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
Posted on May 02, 2009
  • 79 Answers
SOURCE: push rod loose
Hi
Very possible that the valve is stuck open and piston could have hit valve causing it to bend at the head. This would cause valve not to close completely. Would have to remove head and remove valve and most likely replace intake valve.
Posted on Apr 09, 2009
  • 124 Answers
SOURCE: i have a Honda 2216 ride on mower when hot it
Most likely this is a valve problem caused by a carbon build up around the valves. This is not a job for the novice due to it being an overhead valve engine. Poor quality gasoline can cause this problem. I recommend that you always use white gas if it is available in your area. If it is not available try to find the gasoline that has the lightest yellow color. The darker the yellow color the more sticky varnish deposit that will be left behind. And totally avoid gasoline that has a orange color. The darker the color the more problems it will cause.
Posted on Sep 13, 2009
miket756
  • 2702 Answers
SOURCE: craftsman riding lawn mower tries to start and
it sounds like its the exhaust is blocked up or/and air filter, its the back fire that makes me think its a blocked exhaust,, iv had it before!
try taking it off and starting it up,,,,and yes its going to be noisy if it go's! untill you clean out the pipe, then put it back on again,
Posted on Nov 16, 2009
  • 6468 Answers
SOURCE: My Sears Riding Mower Runs Rough & Backfires
don't know the model but check the valve adjustment
Posted on Apr 08, 2012
I have a 18 HP OHP ran out of gas and it backfired and now won't start Could it be the shear key
does it backfire when trying to start?
if so check the flywheel key
as far as running out of gas , check carb bowl and clean
Nov 24, 2015 | Garden
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Apr 07, 2012 | Garden
Overrevving ht 3813 lawn tractor
Check your governer linking. It sounds like it may be loose or bent.
Mar 11, 2012 | Garden
After running husquavarna riding mower 23hp mower starts backfiring and ends up quitting. mower will start back up but die out again as descibed.
I had the same issue and after trying everything I tokk the gas cap off and noticed there was negative pressure in the fuel tank when I broke the seal... I'm pretty sure the gas cap was just too tight, I threaded it back on but did not torque it down and the mower is running fine.
May 13, 2011 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Does the Honda 3813 take a positive or negative ground?
Most all garden tractors here are negative ground. I have seen only a few things positive ground, and that was an old land rover and old jaguar, Both british made. I couldn't find any reference to it being different. Hope this helps.
May 10, 2010 | Garden
Does the gx 340 have a timing belt. I have a honda 1011 riding mower that backfires when trying to start, the fly wheel sheer pin is ok.
What engine do you have ? Some have a selonoid on bottom of bowl of carburetor if bad can cause your problem.
May 12, 2009 | Garden
Push rod loose
Hi
Apr 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I am looking for sevice bulletins for honda 3813 lawn tractor
I had a similar problem with my Honda 3813. When I tore it down, I found that the 3813 has a slow delay cyclinder - something like a shock absorber - the slowly puts pressure on the clutch plate after you let up on the clutch pedal. In my case, the clutch is old and worn, this is exactly the symptom I experienced because the clutch was nearly worn out - it took like 10 or more seconds to get going. A new drive clutch and a little adjustment fixed this problem for me. To replace the clutch without removing the engine I had to cut the cross brace plate on the bottom of the tractor.
To get to this you need to remove all the tin that is under the seat part of the tractor - a real nuisance.
Also, it took me 3 months to get the clutch from the Honda dealer. .... definitely not helpful! Good thing I had a John Deere as a backup, I've never had trouble getting parts quickly for that.
Mar 13, 2009 | Garden
Garden Logo
101 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Superior Maintenance
Are you a Sears Garden Expert? Answer questions, earn points and help others
