Question about Linksys Wireless-N WRT150N Router
What to do when security light is orange? - Linksys Wireless-N WRT150N Router
  • 37 Answers
Reboot
  • The most basic way to attempt to fix a router problem is to reboot the device. This is accomplished by unplugging the powerWhat to do when security light is orange? - icon1.png cord, waiting for a minute and then plugging the power connector back in. If the orange light continues to blink, you will have to update its firmware.
Download New Firmware
  • Even though the wireless router is malfunctioning, downloading new firmware is possible by disconnecting the malfunctioning Linksys device from the Internet connection in the wall, then using that jack to plug your machine directly to the Internet. If this is not possible, use another computericon1.png that can connect to the Internet. You can download a firmware update directly from Linksys (see Resources).
Install New Firmware
  • Once you have the firmware update available on the computer affected by the malfunctioning router, open the file and follow the instructions to upgrade the devices firmware.
Posted on May 12, 2014
Red light comes on, instead of turning to green when ready it is turning orange.
RED LIGHT IS ERROR IF YOU HAVE AN ORANGE LIGHT YOU HAVE TO DO DESCALING TO REMOVE ERROR FOLLOW INSTRUCTION ON YOU MANUAL IF NOT SEND US AGAIN
Mar 03, 2016 | Coffee Makers & Espresso Machines
Land Rover Discovery II, Dashboard Orange light next to the red break light what is it on?
Are you talking about the orange lamp to the right of the brake light in the upper left of the cluster? If so, that is the Malfunction indicator light (Check Engine light for those in the States) or at least it is on mine. Have someone scan it to retrieve and clear the error codes. Google the retrieved codes and you'll find a myriad of hits containing troubleshooting advice. Or post them here and we'll try to get you pointed in the right direction.
Oct 03, 2014 | Safety & Security for Land Rover Discovery...
1993 camaro no secrty light wont crank
Most all mechanics pull the dome light fuse before working in the interior to avoid draining the battery.. On the 1994-95 Camaro the 20 Amp fuse courtesy light, also illuminates the orange security light in the dash cluster. If the security light is out, and your car won't start, it's because the VATS is in theft mode and you don't see it. Clean the key, if that don't work you may have an open short or broken wire in the orange jacket of the ignition (key) switch. Disconnect the harness connector and connect a matching resistor with the correct ohms of your key inline with the purple and white wires without cutting the connectors off, because you may latter need them. - Original Owner of 1995 Camaro.
Apr 14, 2014 | 1993 Chevrolet Camaro
1996 range rover wont crank
If the check engine light(orange) when dash lights up then it is a mechanical problem. If the orange check engine doesn't light up then the security system is in alarm mode. Must have a tool to synchronize engine computer with BeCM. Very common problem
Nov 19, 2013 | 1996 Land Rover Range Rover
We have 30 optiplex 360 now 10 pcs are not able to start the orange light remain when we click the start button what is th actual problems and how can i solve it
make sure the cpu has secure dust free connection and thermal grease
you might need to replace the psu
if you have added any extra devices to your computer you might need more power voltage or it might be faulty
also check all leads from motherboard to hard drive for secure dust free connections and ram modules cmos battery for dust free secure connections
hope it helps
Apr 10, 2012 | Dell OptiPlex 360 Desktop Computer
Wireless light is blinking orange, switched off and back on again, MAC settings are all set and it still blinks orange. Can you help?
ok if its blinking orange then there's a problem most probably with the wireless. have you tried to desactivate your wireless and then reactivate it again!! or what you can do change the security type and see what it does!!
Jun 01, 2011 | Computers & Internet
Car started an hour ago now wont turn over security light in dash came on and stays on
if the security light is on then it is the VATS system. the ignition switch is fine still.
Aug 15, 2010 | 1995 Chevrolet Camaro
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Orange light flashes 5 times
It sounds like it might be a capacitor or possibly an RPM sensor. If your opener is 10 years or older it might be better to replace the whole unit. your best bet would be to call a local professional.
hope this helps.
Feb 22, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Linksys Wireless-N WRT150N Router Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
