SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
SOURCE: Fuel pump issue, 2004 chevy avalanche
1s the fuel pump should not be that noisy, and the problem u are describing is a defective/worn out fuel pump, it is taking time to built pressure, replace the fuel pump and don't forget to replace the in line fuel filter as well.
SOURCE: car turns over, but won't start
Too many choice.
3 main areas are fuel, spark, air.
Try a shot of ether, if it fires at all, it is a fuel problem.
Then we can get into more detail.
SOURCE: Car will not start, just makes a clicking sound.
if when you jump it starts its your batt if if keeps dying it your alternator the clicking sound is your statrer which means thats good try the batt when you buy a new one it will have a warranty soo if it dies because the alt you will get a new one batt for free (the alt charges the batt)
SOURCE: 94 z wont start
check the ignition fuse, fuseable link and starter relay
Testimonial: "thank you - i'll check"
Hi Kevin Lee, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?did u tried move engine manually ? the problem occure some tin orrrrrr ?
What else would you like to know specifically?
