Question about RCA RTD207 System
When cd's are loaded the door closes and the message reads door openm
  • 38 Answers
Hello Deborah.
I think youre problem is the door-switch. it must be somewhere near the door,
in some drives it`s a microswitch but on most of them it is a simply switch made of 3 small tin-blades which will be pressed together when the door closes or opens.the middle one will get moved.
most of home cinema player`s uses this kind of switch, you should be able to fix it by youreself.
carefully clean the contact`s with a thin felt e.c.t.
then bend the 3rd. contact a little bit towards the middle, 1mm between the contact point`s should be good.
if door is open the 1st and the middle one must be in contact.
also could happen that the screw that fixes the switch get loose due to the vibes and you just have to tighten it.
wish you find the easy one.
good luck
Gue.
Posted on May 12, 2014
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
My cd player door opens then close then stays open
The disc loading mechanism is faulty. Check the loading belt first. Replace it. If this do not help you, replace the disc loading mechanism. if you are not handy, seek tech support.
Jun 04, 2012 | Emerson MS3100 3-Disc CD Changer
Numark cdn 90 door opening and closing cd not reading
my numark cdn90 door opening and closing cd not reading
Sep 05, 2011 | Nu Mark Numark Cdn36 Dual CD Player CD...
My Sony 400 cd player will not play any cd's. When I hit play the blue light is in a continuous blinking mode then I get a message that says loading error. When I tried to open the door it was in super...
Your optics are either Really Dirty, or out of line and you would need a replacement optic pickup. If you are mechanically inclined, it's not a difficult repair and parts can be purchased thru lots of sites. First things first, pop the top and use "Dust-OFF" in the main chasis, it gets bad! Next, if you have a good CD/DVD player cleaner that uses fluid, run it thru a couple times then test any disc. If you don't have one, just about any convenience store has them. Just make sure it uses fluid!. If you still have an issue. post a comment and I can pdf you the schematic of the unit. it's pretty easy to read and follow if your a little more than a novice with electronics. Hope this helps
Jun 01, 2011 | Sony CDP-CX400 400-Disc CD Changer
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
Close door, f22 message, won't start
"F22" is a door latch error. The following link explains:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
Read through all the steps listed and let me know if you still require assistance. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My DCD3000 door closes automatically and won't read discs right
Hi....
If the transport inside is like the NAD players, it's the drawer belt that's the problem.
Belts are cheap but someone technical needs to change it.
Mar 24, 2009 | Audio Players & Recorders
RCA RTD207 System Logo
55 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
