Question about MicroKlen Extend And Reach Klening Kit
How do you get snap end of handle it went up into handle cant get it out
  • karere
    karere May 13, 2014
    its the tip that has threads on it with yellow release button thats the part in handle
2004 grand prix glove box handle broken, handle snapped off and lock mechanism fell out
improvise ,you will find a way to open it ,pull or push the two plastic bars that operate the locking bits on the end
Dec 28, 2013 | 2008 Pontiac Grand Prix
1987 vw gti driver outside door handle is broken and door wont open i want to fix it but cant get it to open to be able to see where it went bad
does it not open from inside if not will have to snap of handle all together and see if you can get a hole of the cable that opens the door with some plyers if not you will have to take of the door card from the inside will be a clart on with limited space then will hve to find the cable to pull to make door open hope this helps ivan
Oct 22, 2012 | 1987 Volkswagen GTI
My cable to my emergency brake snapped off right at the handle, i cant grab any of the cable to release the brake. how difficult is this to repair , or is their a way to release the brake.
I assume it is a foor brake and not a hand brake???
If so, put your head under the dash and look at the brake mechanism. You should see a lever where the cable from the handle went to. Being extremely careful, you can move that lever by hand. Just watch out for the pedal and the brake mechanism that will snap back when its released.
Sep 11, 2011 | Ford Taurus Cars & Trucks
Went to start it, and snapped the pull start cord. Trying to pull it apart to replace it but cant get the front gaurd off from the motor to get to the cord.
Usually, the whole starter mechanism can be removed from the left case by taking off several screws. The spool will be revealed when looking at the rear of the mechanism. Remove the rest of the starter cord from the spool and handle, then turn the spool CW about 2-turns, and wedge it so that the spool doesn't unwind again. Fit a new cord end of the same dimension and about 3-1/4 ft (1-meter) in length into the spool slot/hole, melt the end, and tie an overhand knot in the end. Wind the cord CW until you have about 8" left--poke the cord out of the cord port, push the end through the handle, melt the end, and tie an overhand knot. Stuff the knot into the handle bore, release the spool wedge, and pull the cord through several times to make sure that it works without binding in the spool and retracts fully. Reinstall the starter and test on the engine. Hope this helps!
Nov 10, 2010 | Garden
Driver door handle busted inside, then passenger side the same
Yep, you are going to have to replace the handle...sorry about that.
Sep 14, 2009 | 2003 Kia Rio
Bonnet cable routing Mitsubishi Evo VI
Your cable is generally sold as a one piece unit...cable inside housing. (same as a bicycle brake cable) Many even come with the release handle attached. Therefore, you simply feed the new one in exactly where the old one went and attach it to the lock mechanism. This can easily be done by attaching a wire to the latch end of the old unit and pulling it out from the drivers compartment, then attaching the new one to the wire and pulling it back through. In that way, you don't need to see it to install it (like snaking a wire through a finished wall, without opening the wall.)
If you do it carefully, it should not be that difficult.
Good Luck!!
Aug 21, 2009 | 1995 Mitsubishi Galant
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Replacing door handle???????
gently pry the plastic from the inside working from the hinges to the corner. you will need to put something in place of the screwdriver when you pull it out to go to the next pry position (about every 2 inches. i use apex bits. you can use anything about the diameter of a cigarette. then the screws for the handle will be exposed . it all snaps back together.
Feb 18, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
MicroKlen Extend And Reach Klening Kit Logo
511 people viewed this question
Top MicroKlen Video Game Consoles & Games Experts
James Wishart
Are you a MicroKlen Video Game Console and Game Expert? Answer questions, earn points and help others
