Question about Jensen Car Audio & Video
Why cant i play mp4 video files on my jensen vm9214 car stereo
  • 146 Answers
SOURCE: jensen vm9412 and ipod classic
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible.
I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
Cheers
Posted on Dec 29, 2008
  • 26 Answers
SOURCE: playing video audio through car stereo Toyota Matrix
You're probably gonna need a wired FM modulator. That part will take an audio output and run it into your antenna plug on your radio. It will use a FM channel, but it's wired directly to your stereo. So no static as found with wireless FM transmitters.
Posted on Jan 21, 2009
SOURCE: i need an origenal owners manual for my jensen
www.audiovox.com/manuals/owners/vm9510_manual_final.pdf If i'm not mistaking, this is the closest thing that i could find for the Dual 8180 also
Posted on Feb 28, 2009
tunde007
  • 2382 Answers
SOURCE: need bypass code for jenson VM9214 play video all
Hi, you don't need a by pass code for it.
You only have to connect the earth lead (often pink) to the hand/parking brake to ground. This allows you to use DVD only when the car is parked. When not grounded, you only get a blue screen....
Posted on Sep 01, 2010
ZJLimited
  • 17970 Answers
SOURCE: my jensen vm9214 wont play
This is one video lock condition that you need to bypassed. In THIS LINK can find the solution: Jensen-Video-Bypass-Lockout-VM9214-VM9414-VM9324
I heard this same problem, if it plays when its parked then it has a little safety feature that involves a wire, maybe pink in color for your headunit that will only allow it to play when parked. Now if you splice it into the red or yellow, I'd choose red since its not constant, it will play movies anytime.
If it won't play them even when parked then it is not hooked up to a wire or its hooked up to ground and therefor should be hooked to a positive wire, red or yellow. If you didn't put it in yourself then you can take it to an audio shop, maybe check in phonebook for someone local.
But the easy way would be to use a bypass code since there is ojne for your hu. I copy these instructions from ecoustics.com The parking brake bypass procedure is as follows:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
I don't know if it really works but you could try it, if not use the wiring method above: ecoustics.com/bbs/4/278797.
Hope helps.
Posted on Oct 14, 2010
Why is my My Jensen VM9214 stuck on camera mode
Check your wires, theres a wire for the reverse if your going to use a back up camera, if not do not connect it, you may have had it connected through a speaker wire, if so then thats your issue and once you wire it up right it wont do that any more, had the same issue and thats what fixed it hope this helps
Dec 09, 2012 | Jensen Vm9214 Car Video Player
How to play SWF on my Apple iPad?
Apple iPad doesn't support SWF files, you have to use special SWF to iPad Converter to play swf videos with ipad, plus, you need a special swf player, like this one
http://swfplayer.info/
Oct 05, 2012 | Apple iPad Tablets & eReaders
Jensen vm9214 when i hook my indash to battery only the src button is red it wont turn on t
Did you connect the power, ground and accessory? When doing a bench test for operation, these wires need to be connected.
Sep 30, 2012 | Jensen Vm9214 Car Video Player
How do I find out the code to allow me to bypass my unfashionable so I can be able to use it.
On the main remote press stop twice, then 1, 2, 6, 4. This will get you to the hidden menu which will allow you to bypass the parking brake having to be on. It will also give you an option to play burnt movies:)
Aug 31, 2011 | Jensen Vm9214 Car Video Player
My jensen vm9214 will play my music from my ipod but it will not show a display of the song or anything and when I click pause or play or fast forward on the screen it doea not do it so I have to play and...
First off, is the unit equiped as ipod ready or are you using an auxillary input. If your unit is ipod ready, this means it has the ipod cable to the unit. If you are using an auxillary input, it won't show the name and yes you will have to control your music from the ipod itself. Just some things to think about. If your unit is malfunctioning, I recommend visiting the local stereo shop.
Aug 14, 2011 | Jensen Car Audio & Video
How do I get GPS & bluetooth stufff to go with this system ?
You need the Jenson BTM15 (bluetooth module) and the Jensen NAV105 (gps) in order to have navigation and bluetooth connectivity thru this head unit.
http://www.mobile.jensen.com/accessories/?sku=NAV102
http://mobile.jensen.com/bluetoothcarkits/?sku=BTM15
These units sell for around $50 (btm15) and $200 (nav102) on amazon.com
Jan 28, 2011 | Jensen Vm9214 Car Video Player
I downloaded MP4 videos on my SD card and when I
i had the same problem. It is illegal to watch videos while driving hence why they dont tell you how to play youtube off of card and usb. But after hours of testing converted videos here what works for me. download pazera free flv to avi converter. after that you will have to custom convert the videos with these settings....video format is MPG custom MPEG-2/ FPS 29.97. Audio mp3-mpeg- layer 3/ bit rate 128 and i added stereo-2 for kicks. last but not least custom resolution (Based on size of screen) 720x480. (for 3.5 inches. you can adjust for size. convert and it works :)
Sep 28, 2009 | Jensen VM9510 Car DVD Player
Jensen vm9511ts wont play mp4 without link
I don't think there is one available yet, you could check the local stereo shops. They would be the first to know. Goodluck.
Oct 01, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
75 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
