Question about Panasonic KX-T7731 Corded Phone
Corded phone message light wont light up but i have messages
    Habit-Forming:
  • 12 Answers
The message waiting light is triggered to turn on by a code that is sent from one of two sources to the telephone system's main control box which tells the phone to light up the button. A voice mail system can send the code or another phone can send the code. If you have a voice mail system, and your mailbox received a message, the voice mail system should have sent the signal to the phone system's main control to light up the phone's message light. If this problem only happened one time, then you have seen something that can occasionally happen. If your light never lights up to let you know you have a message, probably there's an issue to look for. The voice mail is usually connected to the phone system with two modular plugged-in wires that are equipped with FOUR conductors each (not just two) and whatever was setup when it was installed must still be connected now, or they'll be problems like this. Check to make certian nothing is unplugged at the voice mail system or at the connections at the telephone system control box, and the wires weren't chewed by mice. If you have an older 624 or the newer 824 control box, the wires are either connected to the phone system's control box on jacks 7 and 8 on the "Main 3x8 Board" or jacks 15 & 16 on the "Second 3x8 Board." If the wires are properly connected, leave yourself a message and see if the light goes on. If it does, listen to all new messages and the light should turn off after less than a minute. If the light never goes on, but it used to work OK, it's likely a wiring problem. If the light never worked from the time of installation, and the wiring is properly connected to either jacks 7 and 8 on the "Main 3x8 Board" or jacks 15 & 16 on the second "3x8 Board", then I'd look at the programming of those phone systems ports to verify they are designated as voice mail ports, if not, message waiting won't work. Also note that each of the Voice Mail System's mail boxes must be programmed to know the telephone system's port (Jack) number associated with the mailbox (e.g. Ext 101 = Jack/Port 1), or it can't signal the proper phone to light the message light.
Posted on May 12, 2014
  • Charles Hart May 12, 2014
    Before you do anything complicated, unplug the power from the telephone system and from the voice mail systen for a ninute, then reconnect the power to both, After a minute or so see if it all works... sometimes a power glitch can cayse odd problems, and a power reset clears them up.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Replace led (bulb)
Posted on May 11, 2014
Blinking light voice mail ms9 via phone co wont turn off
The blinking light usually means one of two things: 1) message box is full or 2) you have a new message. Deleting messages should solve this problem for you. After you delete the messages, if you still have a blinking light, unplug the power cord and take the batteries out of all the phones linked to the base unit. Then one at a time put the batteries back in after you plug the base unit in. This should clear and error. Some base units have a back-up battery, don't forget to remove it too!
Apr 14, 2015 | Lands Phones
Message Light
The only thing you can do is unplug the unit from the wall and from the phone line. wait over night and see if this resets the unit. if it does not, I,m afraid there is a circuit problem in the phone and most likely will not be worth repairing, but try to hard reset like I said first. good luck
Jun 11, 2007 | RCA 25414RE3 Corded Phone
Why is the message light blinking when i have no new messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Feb 04, 2013 | Comdial 8324S-PT Corded Phone
The "Message" light is lit
Another person in your office could of mistakenly turn your message light on. To turn off your message light press feature 10 then your extension number (feature 10 xx).
Nov 18, 2010 | Avaya 700340193 Corded Phone
Why wont red Message light on my Nortel Phone
more than likely someone in your office left the message rather than the voice mail. to clear it press the call soft key below the screen. the screen should display who left the message with two of the soft keys labeled call and erase. press the erase soft key. it's possible the the person/s that left the message left multiple messages. in that case repeat the procedure til all messages are canceled
Jan 13, 2010 | Nortel T7316E 2-Line Corded Phone
Message light wont go off
press speakerphone and then press 700 and your ext #. Your lite will go out.
Jun 24, 2009 | Panasonic KX-T7453 Corded Phone
When call goes to voicemail, it says call being transfered
I understand that you would like to bypass Auto Attendant for your lines.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercome
#208
Line 01
Enter your extension number
#208
Line 02
Do the same for all of the lines.
Go to your extension to program a voicemail cover button. Without it being on voicemail wont pick up
Press Feature 00
Select a button and call it Call Cover press it
Enter Feature 15
Feature 00
Press that button so the green light lights up.
Test.
Jun 18, 2009 | Lucent PARTNER18 Corded Phone
T7633 message lamp does not light up when there is a message
Go to any other phone and call the phone that the message does not work. When it rings, press the MESSAGE button. If it lights, then it's working.
Now, what is leaving the message and is it set up properly? I'm guessing it's a TVA voice mail system and it has to be told where to light the lamp.
Carl
Mar 31, 2009 | Panasonic KX-T7633 Corded Phone
Message waiting light
Go into the voicemail, press 5 for message waiting notification options, press 1 for message waiting light status.
Aug 08, 2008 | Panasonic KX-T7633 Corded Phone
Model 4025
In the days before voicemail, Mitel had a "Call Me Back" feature that would light the MWI. We now use the MWI for voicemail, but the capability is still there. You can solve it several ways.
1. Go to the blinking phone and press the Messages button. One of those should be "Call me back". Press it and when the other party picks up, the MWI should turn off.
-or-
2. Look up the FAC for Message Waiting - Deactivate in your phone switch. On my switch it is *91.
Feb 13, 2008 | Mitel Superset 4025 Corded Phone...
Panasonic KX-T7731 Corded Phone Logo
126 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
