Question about Franklin 2823008110 - 1.5HP Submersible Control Box
Pump pulls to many amps keep having to press reset button is this my motor going out or what if so what motor goes to model 2823008110
    Top Expert:
  • 3,698 Answers
Yes , motor likely going out.
Posted on May 11, 2014
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
How do I reset machine after warning light for draining
what make what model
your question is far to vague to know 20% of what you want
usually you press and hold in either start stop or reset
and then turn the mains on keep holding the button
most machines give a long beeeep then reset
if you still have issues perhaps the pump motor is being detected as bad...
Feb 07, 2015 | Washing Machines
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
The motorized wand attachment keeps shutting down after 10 to 15 seconds after pushing the red reset button. I've thoroughly cleaned dirt/debris from around motor. Do I need a new reset switch? Thanks,...
either the reset is bad or the motor is drawing too many amps and tripping the reset. Do you have an amp meter? Check the amps being pulled by the wand attatchment against the load recommended by the manufature, this is usually located on a plate somewhere either on the wand or the canister.
Nov 24, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I have an e50 fault flashing on the display
Hello, E50 is relating to the main motor,it could be the brushes,tacho or something more serious.,try checking the brushes first follow these instructions.
Hold the start/pause and skip/reset together then press the on/off button keeping the other 2 buttons held until you get chasing lights,now release the first 2 buttons.Now press the fabrics button until the light goes down t60 degrees or the pump cuts in.Then take it on I think step by step until an error code displays make a note, to cancel hold the 2 buttons start/pause and skip/reset and the error code should go but if it reappears then the fault is still there.
Thanks
Jun 14, 2010 | Zanussi ZWF1430W Front Load Washer
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Mar 11, 2010 | Pioneer VSX-1019AHK A/V receiver
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Franklin 2823008110 - 1.5HP Submersible Control Box Logo
111 people viewed this question
Top Franklin Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Franklin Plumbing Expert? Answer questions, earn points and help others
