Question about Amana NED7200TW Electric Dryer
What does it mean if my drier smells like gas?
    Sergeant:
  • 194 Answers
It means there is a leak. You should turn off the gas flow to the drier immediately until it is fixed!
Posted on May 11, 2014
Lg gas dryer something burning
burning smells in driers can be sometimes from a blocked lint filter. The dried lint has been known to ignite when it gets hot. If you haven't cleaned the lint filter then do so and if the smell continues get it serviced.
Nov 20, 2014 | LG Washing Machines
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
How much gas go into the ac
fast vacum by drier 2nd line & run compressor.when all air out by drier 2nd line.(have connected gas metter & gas clynder.)then gas charge 12 to 15 presser & use pancing tool block the drier 2nd line,cut it line solder it.
May 31, 2012 | 2006 Rover 75 Connoiseur
Bad gas smell coming out of the dryer vent, its gas by the way. Im a general contractor so I bubble tested the fittings and inside with the door of the dryer closed, no smell, but outside...whoa!!!! I...
what about the hose from the wall to the drier
they leak from pores in the rubber lining
get a gas sniffer and find the leak before something nasty happens
Jul 11, 2017 | Dryers
Hi, I have the Asko dryer T721. It's about 6 years old and is starting to emit a gas smell when it is on. It also seems to be taking a lot longer to dry. I have followed the manual to clean it and it works...
Umm, i think its time to say goodbye to your drier, i had a drier, when it got past the 4 year mark, it made a weird smell, then it kind of set itself on fire, call asko if you can, ask them....
Jul 20, 2009 | Asko Dryers
Runs louder than normal then just stops.
most common causes of a noisy dryer are bad drum support rollers, a bad idler pulley or a bad blower wheel
May 04, 2009 | Maytag MDG9206 Dryer
Face of the drier
No, there is no access panel in the rear of the dryer.  Everything comes off from the top or the front.
Apr 15, 2008 | LG DLG5988 Gas Dryer
Tecnik washer/drier
Leave the door open after using to prevent mold problem.This should help alot.And needs to be left open just partially.
Jan 14, 2008 | Tecnik TKL9260 Front Load Washer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Amana NED7200TW Electric Dryer Logo
55 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
