Question about Briggs & Stratton Garden
Craftsman lawn mower briggs and stratton 6.75 model 917.370640
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 8 Answers
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Posted on Jul 01, 2009
  • 133 Answers
SOURCE: 4 cycle, 5hp briggs and stratton, lawn mower
Try taking off the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs on the magneto. Also clean the end of the spark plug wire. I use fine sand paper or emery cloth.
Good luck and let me know if this helps.
thanks roundo4
Posted on Sep 06, 2009
  • 302 Answers
SOURCE: craftsman 19.5 - keeps flooding getting too much gas
I think that you have a sticking float in the carb. You probably will have to rebuild it. hope this helps
Posted on Sep 20, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman lawn mower. Briggs & Stratton 6.75
1) check plug for being carbon fouled or fuel fouled. Even though it fires, it may not be firing correctly
2) make sure you have compression 75-100 psi. since the compression release so you can pull the rope works off of the exhaust valve, you may not get anymore than that.
3) Is there water or debris in the float bowl
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 26, 2009
675 Briggs & Stratton Power Propelled, Electric Start, Model 917376531. Where is battery located?
Margaret, you plug your charger into the battery, the lead or connection for charger is attached to battery and that is where battery is located. Check the attached links,instruction and guides, Good luck Battery is # 74 in link picture.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ubermanuals.com/product/craftsman-917376531-13041
CRAFTSMAN MOWER Parts Model 917376531 Sears PartsDirect
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/917376531.html
Craftsman Washer 917376531 Parts List
How to charge the Craftsman 650 battery start lawn mower model 917 37641
Apr 15, 2016 | Briggs & Stratton Garden
Owners manual for craftsman lawn mower model 247.37031
Go on Sears web site to see if you can download it there.
Nov 20, 2015 | Craftsman Garden
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Oct 01, 2014 | Briggs & Stratton Garden
Craftsman lawnmower
take back get new one handel probably broken
Aug 16, 2014 | Briggs & Stratton Briggs Stratton...
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
I AM LOOKING FOR: Craftsman model 944360300 lawn mower manual
Contact Sears as they sell Craftsman exclusively. I am sure they can help you out.
Sep 22, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
