Question about Dell Computers & Internet
How to repair a picture of microphone/speech recognition is frozen on monitor?
I have a Microphone/speech recognition tab/app that is frozen on my computer monitor. It will no longer work (says it I sleeping) & I can no longer move it, how do I fix this?
sandrew
  • 2961 Answers
SOURCE: Microphone trouble on 5050
assuming that the mic itself isnt faulty, go to the right side of your taskbar and right click on the grey spekaer, not the red one and click on recording devices. When the window pops up make sure the mic realtek HD audio has a green tick and not the line in icon, next click properties and check the settings,you can also configure the mic from this window.
Posted on Sep 16, 2007
SOURCE: pc microphone
i found a solution under the control panel. to configure some settings under the default view of the control panel, use the Ease of Access icon. this does not allow you to see the actual device. by switching to the classic view, use the Speech Recognition Option, which showed that i had 3 microphone drivers installed. all that needed to be done was to select the one i was using as the default.
Posted on Mar 09, 2008
  • 66 Answers
SOURCE: Monitor Microphone
make sure you have the mic cable plugged in the right port at the back of your computer. double click on the speaker on your desk tray, lower right corner by the time-date location, the Volume Control window will open. Check if you have the Microphone column, and the Mute check box is not mark. If you can't find the Microphone column in your Volume Control window, click Options > select Properties... check the box that says Microphone... then click OK. Now you should see the Microphone column... uncheck the Mute box. Test your mic now....
Posted on Jun 02, 2008
SOURCE: microphone
there is NO microphone on the fp5315 monitor. I have two of these monitors myself .
Posted on Oct 08, 2008
  • 136 Answers
SOURCE: Not able to record sound on Conexant AMC
Maybe you should uninstall and reinstall the drivers, so that the mixer device is set properly.
Posted on Oct 31, 2008
What function key turns on the microphone?
go to start->control panel->speech recognition->setup microphone->select desktop microphone then click on next. make sure the mute is unchecked
Feb 19, 2014 | Dell Computers & Internet
Laptop microphone problem
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable
Feb 14, 2013 | Computers & Internet
How to fix my laptop microphone
Step 1:
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a Microphone Headset with Microphone then next and next again you should see your Earphones with Microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the Microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for Microphone has a tick in it
Microphone is plugged in but not working
Feb 08, 2013 | Samsung Computers & Internet
Microphone doesn`t work
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Jan 05, 2013 | Dell Inspiron 15 1545 Notebook
Im using acer aspire 4732Z. When i use skype the other person cannot hear my voice? What might be the problem? do i need a separate microphone?
Good day,
I will first want to ask that do your laptop have a built in microphone like that use for speech recognition? If yes, has your skype account been configured to use this microphone? if no, configure that in the settings tab of your skype account.
If your laptop do not have an in built microphone then get a head phone that has a microphone attached to it and configure it in your skype account.
May 24, 2011 | Acer Computers & Internet
Speech recognation tab is missing
Do  you want to use speech recognition......
there are softwares in the market for that kind of control. anyway the use of microphone does not require the speech  recognition tab
what you should chech is the sound and audio driver and check whether you have the driver  fully installed  check under the voice tab there.
if this help pls tell otherwise please post further comments on your problem.
happy to help.
Nov 20, 2008 | E-Machines eMachines Desktop PC
Pc microphone
Mar 09, 2008 | Plantronics Audio™ 350 Headset
Vista 64 microphone not working
hmmm did you try a different mic, and exure its jacked into the mic in of your sound card.. If you have dual sound devices, ensure its in the correct selected device...
1.)To see which device you have as the selected device, Click Start, All programs / accessories / entertainment, volume controll..
2.)Choose Options and then properties
3.)In the mixer device drop down list, ensure that the correct device is selected. Click on the drop down list to see all aviable devices..
4.) Now under the Adjust Volume For selection select recording
5.) In the Show Following Volume Controll Box, select Mic,(make sure its ticked)
6.) Click Ok
7.) The mic and aother controlls will show up, under mic ensure select is checked..
NOW TEST YOUR MIC..
1.)Start, All programs / accessories / entertainment / Sound Recorder
2.) Click Edit then Audio Properties
3.) Under Sound Recording Select the Appiorate device..
4.) Click Record and try it..
5.) Stop it and play it back..
IF THAT DONT WORK REPLY HERE AND WE WILL HAVE A LOOK AT THE DRIVERS..
Jan 13, 2008 | Creative Labs Sound Blaster Audigy LS...
Computers & Internet Logo
11 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
