Question about Maytag Dryers
Maytag dryer will heat up the first time but not again. Igniter goes on but doesnt light.
S# SDG515DAWW M# 17660570ev Vent pipe has been removed & cleaned
    Problem Solver:
  • 6 Answers
Replace both valve coils. They will open the valve the first time, but when they get hot, they become intermittent at best.
Posted on May 12, 2014
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
  • 1314 Answers
SOURCE: Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Posted on Dec 30, 2007
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
Illeagle
  • 525 Answers
SOURCE: dryer wont heat
About all that is left to replace is the flame sensor mounted at 9o'clock on burner flame tube, but I would double check your airflow, This is CRUCIAL to the normal operation of the dryer.
Also, a lint filter with an invisible coating from fabric sheets can cause an airflow disruption, try running without clothes and the filter removed.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
SOURCE: Maytag Atlantis Dryer
As you are looking at the igniter you may notice a little rectangular sensor to the left.
This tells the dryer that the igniter is glowing and it is OK to open the natural gas valve. If this sensor isn't working, the gas valve remains closed
Once the burner is lit, there is another sensor above the flame that is round. (flame sensor) This tells the dryer that the flame is lit.
If this sensor isn't working the dryer turns off the burner after a brief period.
This sensor can be cleaned or replaced.
Posted on Jul 22, 2009
Sdg515daww maytag legacy series gas dryer will not put out any heat until the dryer has been on for about an hour or an hour and a half...have cleaned external vent tubing and vacuumed (as far as vacuum...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Dryers
Doesnt dry clothes, every opening i have unclogged,even outside vent is clear.basket rolls but heat is room temp. no matter what setting.
Hi, I experienced the same problem with my Maytag electric dryer. I finally fixed the problem after I checked the actual vent pipe (which allows air to discharge to the outside of your home). What I found was quite surprising. I found was a mouse nesyt in this pipe. Once I removed the mouse next,m my electric dryer worked fine. Just a thought. Good Luck!
Jan 09, 2011 | Roper REX4634KQ Electric Dryer
Replaced igniter in gas dryer,it ran about 12 loads and now doesn't heat again. took out igniter and it seems fine
the dryer has several operating and high limit thermostats in it usually in the back of the dryer under the back panel. these need to be tested. there is also a very good chance that your dryer is not venting properly. examine the vent pipe especially where it goes outside the house. when it is running there should be very good air flow. if not, you need to find the obstruction.
Oct 17, 2009 | Maytag Dryers
Gas smell from outside vent, but heats up fine, it is a maytag performa gas dryer. the igniter was just replced and i checked all connections with soapy water
It may not be burning clean. First thing you have to do is make sure that you dryer is vented right.
  1. make sure the vent pipe is not kinked, bent to sharp.
  2. Not full of debris.
Venting is important if it is abstructed then the gas backs up..
you may need to adjust the flame of the burner.
Sep 13, 2009 | Dryers
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 03, 2009 | Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
