Question about Dryers
Kenmore smartheat quiet pak 9
Says lint filter needs cleaning. It is clean. How do you get bottom front off to take a look. I see no screws holding it on.
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
  • 2333 Answers
SOURCE: I have a kenmore elite smartheat quietpak 9
make sure it is not set on air only,just went to a job and that's what it was lol.unplug dryer,take off bottom panel,on right side you'll see the heating element,pull off one of the wires and read out heater with a meter,if it's bad you'll need part number 3387747
Posted on Nov 07, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Elite Smartheat He5 front load dryer will
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 30, 2010
heatman101
  • 43501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore Elite Smartheat Quiet Pak 9 gas dryer HE 4T won't start
does it heat up, when it works does it dry right.
Mar 03, 2012 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Have Kenmore 90 series elec. dryer...will start, but then cuts off and doesn't dry clothes. Trying to clean the lint out of it. We've taken all the screws out of the back, but can't get the back off!...
Hi-I just cleaned out mine. You take off the clamp that holds the exhaust duct from the bottom of the back of the dryer and you will be able to vacuum it out. Then you can remove the kickplate on the front of the dryer by lifting it hard and pull the top of it out. Then you can remove the lint trap holder once inside by unscrewing it, remove it and clean it out(take out the lint filter first). I vacuumed out the inside of the exposed bottom gently cause it was so full lint! Hope this helps!
Jan 23, 2010 | Kenmore Dryers
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite smartheat quietpak 9 model#110.85872401, it will not heat up just cold air. the air lint filter is clean.
Nov 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore smartwash quiet pak 9 is leaking
The lint is likely from the drum seal rubbing over time.
Aug 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore smart heat quiet pak 9, just beeps won't start
m dryer did the same thing tonight and it was the door switch luckly i wiggled it and it came back on
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Noise from the lint vent
idf top mount filter remove screws under filter lid remove nback cover remove 4 screws holding cover and lint housing to back pull housing down and out ..something may be hitting wheel just clean and reassemble ..on inside door filter remove bottom cove remove filter remove screws holding filter/blower cover in place ckd for smae objects clean and reassemble
Sep 02, 2008 | Kenmore 63012 Electric Dryer
My Kenmore Elite has an error code of F then the number 51. I would like to know what this means. Can you help? It is a Kenmore Elite, Canyon Capacity. Quiet Pak 9, Oasis HE Energy Star, will this...
F51 error code is beacause the computer board did not receive input from the motor on the bottom. Unplug the washer, pull the machine forward and tilt the machine back. On the bottom you will see a large white wheel with a silver allen screw in the middle I think it is a 6mm allen wrech that takes it off. Once you remove the screw and drop the white wheel, there will be a large coil of wires with 4 5/16 screws holding it on, remove these screws and drop the coils. On the right hand side you will see a connector with three wires , unplug it. Use sand paper or a scraping tool to clean all 3 male sides of the connectors. Reverse process to re-assemble.
Jul 11, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
