Question about AEG Washing Machines
Aeg wont stop filling water
Won't stop filling water
    Sergeant:
    Champion:
  • 282 Answers
Check the timer. The motor could be frozen or burnt out.
Good luck,
Marty
Posted on May 11, 2014
  • 790 Answers
Should be a water level control switch.
3 Suggested Answers
  • 867 Answers
SOURCE: Water won't stop filling
If the water still flows in when the machine is off the inlet solenoid is faulty, if when you push start it fills and keeps filling then the problem will be with either the electronics or the pressure switch.
You really need to get someone who has experience with whirlpool machines to look at it for you.
Posted on Mar 09, 2012
  • 1462 Answers
SOURCE: aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Posted on Mar 21, 2007
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water....
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Nov 15, 2010 | AEG Lavamat 88840 Front Load Washer
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
Feb 12, 2010 | AEG Lavamat 72640 Front Load Washer
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG 62600 Will not fill. Hose from tap is clear. Help
Try filling with hot and cold water, the water valve solenoid may have failed.
Jun 01, 2009 | AEG Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Aeg washing machine
Mar 21, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
