Question about Airlink 802.11G Wireless 4-Port Router (rt210w)
VPN with airlink super G 101 router
I have a airlink super G router connected to my DSL modem. I can access vpn directly from DSL, but not after the super G router. what can be the problem?
SOURCE: Site to Site VPN between DI 804HV and Sonicwall TZ190.
open port udp 500
Posted on Apr 08, 2008
SOURCE: vpn in 3com router
10.10.10.1
Posted on Aug 09, 2008
ebarrick
  • 38 Answers
SOURCE: reset admin pw on Linksys RV042 VPN Router?
unplug router on the back is a reset hole use a pen or paperclip and press for 30 seconds this will set the unit back to factory settings
Default IP: 192.168.1.1
Username: Admin
Password: Admin
http://www.smallnetbuilder.com/content/view/30186/51/
Posted on Apr 16, 2009
SOURCE: Cannot get PPTP VPN to connect via Westell 327W (Verizon DSL)
Is the VPN server that you are trying to connect behind a firewall?
Posted on Jul 27, 2009
SOURCE: I CAN'T ACCESS INTERNET ANYMORE VIA AIRLINK AR325W ROUTER
problem resolved. thank you.
Posted on Oct 15, 2009
HN9000 won't pass remote services
On the Router check if you have UPnP enabled, if yes then Disabel it that should fix the NAT issue and then you need to open the port number 1723,3389. Once these ports are opened then you will be able to access it on the VPN and Remote Desktop Provided you have a WAN IP Address from your ISP. also check the Firmware of the router if its updated or not.
Mar 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Belkin F5D9230-4 won't allow a connection to M Exchange server
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
  1. What OS are you running on your pc?
  2. What VPN client are you using on your pc?
  3. Ask the administrator of the Exchange server if they're using PPTP or L2TP for VPN connections.
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
Aug 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
Airlink AR670W connection issues
You need to power down the modem, router and computer then turn them all on in the order - modem first, then router, then computer... Doing that and barring anything else that should work for you!
Apr 03, 2009 | Airlink AR430W Wireless Router
DSL connection not being shared by Linksys RV042 Dual Wan router
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
Feb 24, 2009 | Linksys RV042 VPN Router
Cannot connect to remote Microsoft VPN
Hello, some ISPs require someone to manually/staticly assign a default gateway for a router. With computer connected directly to ISP modem, if using Win XP click start, run and enter "cmd". This will bring up a black text box(CLI). at the prompt> enter ipconfig and click enter. This will show the computers IP address Subnet mask and default gateway. You will need to connect the modem to router to computer. If you haven't changed default settings, From browser enter 192.168.1.1 in window. Enter. This will open router settings. Username and password will be "admin". It may require admin for either or both. You may have a Initial set up link. From here you'll need to enter Default gateway address to access the modem and internet. Hope this helps
Mar 19, 2008 | D-Link DSL-G604T Wireless Router
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Connecting VPN using Netgear 624
This is no small undertaking. You will first have to decide if you are going to use software or hardware vpn. Software vpn is free and only requires that you install it (the client) on whatever remote system you are using to connect to the 624. I can say that you want to have your internet connection point (DSL modem or Cable modem) set to "bridge" mode. This will pass through all traffic to the netgear directly. Some (like a speedstream 5200 DSL modem) allow this or they have a DMZ feature which will accomplish the same. Either way you want to ensure ALL ports and all traffic are getting to the netgear. Once that is done you simple create a string at both ends that match for your security phrase and an authentication that matches and you should be good. It's really a lot more than what could be provided here. (Several lengthy documents worth) but I can provide you with a useful link that will give you an a-z about VPN and has specific walkthroughs for Netgear users only. http://www.vpncasestudy.com/index.html Hope this helps a little.
Aug 22, 2007 | NetGear WGT624 Wireless Router
Airlink 802.11G Wireless 4-Port Router (rt210w) Logo
224 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Mike
Nelson Olazo
Nelson Olazo
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
