Question about Shoprider Health & Beauty
Shoprider jumbo scooter suddenly stops and is beeping.Turn off.. restart...goes 6" stops?
Looked for any obvious loose connections.Pushed the reset button under seat.Moves 6 " fore or back. Stops suddenly
SOURCE: scooter will not charge
sounds like the gell batterys you can try a battery conditioner it may charge them enough for your charger to work again .if the batterys are not charged or used for a wile the batterys will not let the charger work they should be charged almost all the time
Posted on Oct 11, 2008
  • 11 Answers
SOURCE: User manual for shoprider madrid mobility scooter
Go to the Shoprider website and look for the scooter. It might have a different model name than the one you own. Get the name and click on the user manuals for the model that resembles yours (PDF file) and print.
Posted on Apr 02, 2009
  • 11 Answers
SOURCE: sudden stop
If it's not that your batteries are low, it probably will be your front to rear wire harness. Could be that there is a short on one of the wires. Common problem when wires are zipped tied to tight. On most cases scooters cut off power when turning.
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
  • 177 Answers
SOURCE: Scooter moves approx 10 feet then stops led flashe...
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
Posted on May 28, 2010
I have a shoprider model no.ph8-c new batteries and fully charged but only goes a few yards and stops any ideas I can't find a manual online for it
See if you bang on the top of the tiller when you start driving if it stops, then could be a bad Throttle Pot. Watch to see if only happens when you hit a bump or a certain speed, also watch to see if the power goes out this would indicate loosing a connection to the brain box or loss of a battery connection.
Oct 06, 2016 | Shoprider Health & Beauty
Stops suddenly, immediately restarts
Look for a loose connection on the throttle pot. really sounds like a a connection that is loose. Scooter Doctor App
Apr 09, 2016 | Pride Mobility Legend XL 4 Wheel Electric...
Why don't the turn signals flash on shoprider cadiz deluxe?
hi Vic, there a little black board under the tiller part , it got a ribbon cable to it so take care if looking at it , there's a fault with the circult..
Regard
Rob
Help me Help you ...
Sep 24, 2015 | Shoprider Health & Beauty
How do i turn off the terrible beeping that goes off when my scooter goes backwards.
It has a purpose and that is, warning anyone behind you. Better to put up with that, than be confronted with an insurance claim.
Apr 26, 2014 | Shoprider Scootie Jr
Altea 4 stopping an alarm going of
Hi, normally this is a loose connection.... Could also imply the throttle is worn , try pushing the lever in the upwards or downwards direction.. Does it cut out ?
Regards
Rob
www.gewizrepairs.co.uk
Jan 01, 2014 | Echo 3 TE SL7 3 New Electric Scooter by...
Older Shoprider 778b goes backwards when key is turned on, what's up? Check all connections.
The throttle set screw may have slipped a bit causing it to be a little bit on so when you turn the key on it moves forwards or backwards loosen and reset throttle bar and it should stop doing this.hope this helps Richard
Jun 22, 2013 | Shoprider Sprinter Xl3 Deluxe 778XLSBN
Push button to turn on and it just flashes and beeps
Hello,depending on what the series of beeps are & on whether it is a scooter or wheelchair.Then you can work out the problem.If you are trying to repair yourself,"please take a pic of anything before you touch on your mobile say,for relaying back to".Have a look at:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772,Download as a PDF File to view.Hope this was of help,have a nice day.Colin
Mar 05, 2013 | Shoprider Health & Beauty
Shoprider mobility scooter seems to die of power on incline and battery level indicator goes down to half way can anybody help thanks
Hi my shoprider mobility scooter keeps stopping. Have to switch it off for few mins then it worked. Now when it stops its not starting again and has to be pushed. Has new batterys about 6 mths ago and have checked all connections but cant find any problem. Please help. Pam x
Jun 04, 2011 | Shoprider Sunrunner 4 Deluxe
Shoprider scooter what it does is that runs for about 1hr. or 11/2 and make a sudden stop and started beeping and it doesn't move. I turn off the key and wait for about 1 min. and turn on the key and start...
i have the same problem with my pride hurricane ,
i am looking into the throttle potentiometer to see if that is the
problem,
i will post on here if i find out,
let me know how you get on !
Nov 02, 2009 | Shoprider Sprinter Jumbo 3
Shoprider delux scooter completly dead but new bateries fitted
check key tubler is not faulty,no connection has been or worked loose,fuses for each battery are not blown press curcuit breaker to reset.get the wiring feed checked from batteries to see you have power by an electrician.
Mar 24, 2009 | Shoprider 889XLSN-BGRD-Enclosed Cabin...
Health & Beauty Logo
52 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
