Question about Sanyo Counter Height, 3.6 Cubic. Refrigerator W/Timer Auto Defrost, White sr36
What type of a compressor that the sanyo SR - 36A uses? and can it work if remove a 110v compressor and replace it with a 240v compressor?
The fridge is an American it cme with a 110v compressor now its not working togheter with its step up transfomer,so am plaining of replacing it with a 240v compressor becouse where i am we use 240v power and not 110v
    Sergeant:
    Champion:
  • 282 Answers
You can use a 220 volt compressor, just make sure the evaporator fan is also 220 volts as well as all of the bulbs, and anything else that is 120 volts. Everything must be 220 volts. including the start and run capicitors.
Good luck,
Marty
Posted on May 11, 2014
I want to remove the freezer tray from SR-2570M. Can this be done without removing the refrigerant?
No. The freezer "tray" is the evaporator, and therefore, the most important part of the unit. (this applies to most mini-fridges out there)
Mar 23, 2016 | Sanyo Sr-2570M Refrigerators & Freezers
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
What is cubic feet of sanyo sr-366w
mesure the inside of the refrigerator wxhxd = q" then multiply q" by 1728 = q'
Jul 26, 2014 | Sanyo SR-366W Undercounter...
FFB6187
Try rearranging all items inside fridge and freezer so that air may circulate around all items easily and then check seals on doors and ensure doors are closed completely and not leaking cold air. Also do a complete thaw/ defrost. You can remove the plastic coverings and ensure all ice is defrosted. Using a hair dryer will speed up thawing/defrosting process.
Nov 06, 2013 | Freezers
Compressor working fridge is not
Not a 5 min. explanation, but in short, if the compressor and fan are both running, question is, Is the freezer cold but not the fridge? If so, defrost properly for approx. 12 hours to remove all ice then restart. If not, one of 2 options remain, there is either a Blockage in the system, or there is a leak in the system. Either way, you need to call a service technician. Truthfully, if diagnosed with a leak, i suggest you replace the fridge as these leaks do not get repaired properly especially if it is internal and good money will get wasted. Hope i helped.
Jul 29, 2013 | Whirlpool 19.6 cu. ft. Upright Freezer...
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer not working
Thermostat can easily be determined, it has knob or a display for digital control. If it is a knob try to set it to high cool but if wont work.Try to unplug the unit and pull out the thermostat set it to high cool and check if there is a resistance on its terminals. Or check for open overload compressor Or may be the winding of compressor is open.
Dec 23, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Sanyo Counter Height, 3.6 Cubic. Refrigerator W/Timer Auto Defrost, White sr36 Logo
96 people viewed this question
Top Sanyo Freezers Experts
Jay Finke
Jay Finke
ray gallant
AJMAL KHAN
Are you a Sanyo Freezer Expert? Answer questions, earn points and help others
