Question about Samsung Microwave Ovens
How do you replace the spring attachment on a samsung microwave smh7178std
Microwave runs with no heat and light comes on when door is closed . i have already changed the switches
  • 3 Answers
I'm not sure that the switch was your problem in the first place. But changing it couldn't hurt. But if your unit runs,but has no heat, it is probably the large diode that is connected to the heating unit. As for the light, the bulb may just need to be replaced.
On the other hand, one of the internal fuses may have burnt out, which could have affected both the light, and the heat circuit. In any event, you must first remove the unit's cover to access any of these parts. Good luck.
Posted on Jun 26, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
Posted on Nov 05, 2007
  • 185 Answers
SOURCE: no heat for microwave
its probally the magnatron
Posted on Jun 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung MW SMH7178STD Not Heating
I would think it may be a failure of the cook relay on the board, since the noise is quieter.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Sorry i can't help more. This will need troubleshooting.
Posted on Aug 28, 2008
  • 291 Answers
SOURCE: microwave is running sounds like it is heating but
This is a very complex repair, and should only be done by a technician that has worked on these a lot. The heating problem can be wiring, magnetron, safety thermostats, high voltage diode, transformer, capacitor, or control board. Out of all the brands and models we work on this is one of the toughest to work on because of the amount of labor you have to put into it, to get into the unit to diagnose this type of problem. I would recommend that you use one of whirlpools warrantee companies, as they will probably have the most experience with this model. Good Luck, Appliance Specialists.
Posted on Dec 09, 2010
  • 6771 Answers
SOURCE: Samsung Microwave oven SMH7178STD Light, turntable,
It is more than likely the magnetron has failed, there are two additional parts that can be a factor, the high voltage capacitor and diode, both these parts work with the magnetron to generate the high voltage that heats the food. If a professional does the repairs, parts and labor will be high.
Posted on Feb 10, 2011
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
May 11, 2014 | Samsung SMH7178STD Microwave Oven
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
NEED TO REPLACE KEY LATCH ON DOOR , HOW DO I GET TO IT?
Samsung over- the- range Microwave oven[ SMH7185 STG] won't close.latch?
Jan 02, 2010 | Samsung SMH7178STD Microwave Oven
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
Replacing door hooks
Easy, just pry off the plastic inner door molding and replace the plastic latch hook and spring.
Mar 10, 2008 | Samsung SMH7178STD Microwave Oven
Fan vent door not working
First of all, if it's less than a year old, it will be under warranty and you should contact Samsung to cover the service. You can try the number in your manual or try samsung.com
There is a drive motor that opens and closes the vent fan door. It or an associated switch may have failed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number (SMH7178STD) at http://www.wehaveparts.com
Nov 15, 2007 | Samsung SMH7178STD Microwave Oven
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
