Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Ge refrigerators ic make hook up step by step on the back with images
Whirlpool ed22mk xl fans run, starter is a solid state starter ge ic-13, 3arr42a2. Click, compressor vibrates, sounds like it us running, click, compressor stops.
call the technician for a proper diagnosis and quote
could still be the starter capacitor failure or a compressor seizure
Aug 28, 2016 | GE Refrigerators
GE GSL25IGXB LS refrigerator. No water from front dispenser.Ice making works. Filter is good. Any suggestions?
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
Ice and water not dispensing
check the water solenoid in the back of the unit where the water line hooks up. sounds like the solenoid is not powering to admit water to the ice maker or dispenser.
Jun 01, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ge Freezer not working
with min. toubleshootin. remove food store else where. Unplug unit. mop up water from ice melting. after 12 hour plug back in. If this work let me know. And I let U know step 2. Good luck.
Oct 12, 2008 | GE GSS25JEMWW Side by Side
Double image
you need to replace both convergence ICs they are both STK392-110 you can get replacment Ics at the following link with free step by step instructions with pictures. here is the link.
http://servicemanuals.vstore.ca/
Aug 13, 2008 | Panasonic PT-56WX53 53" Rear Projection...
Freezer is not working properly.
http://forum.appliancepartspros.com/refrigerator-freezer-repair/4220-ge-refrigerators-gs-ps-models-evaporator-fan-motor-test-replacement.html
Try this link with step by step instructions
hope it help
Mar 06, 2008 | GE GSS25LGM Side by Side Refrigerator
ICE MAKER
sounds like icemaker not turned on
Jan 03, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
22 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
