Question about Hotpoint WMA46 Front Load Washer
Hi door latch as broken off, does anyone know the correct part number? cheers steve
    New Friend:
  • 15 Answers
If you look up Hotpoint-Spares.co.uk and select your machine model and you can purchase it on line or ring them up on 01489 782492 they are very helpful. Hotpoint Spares co uk For all your hotpoint spares and accessories
Posted on May 29, 2014
Creda simplicity dryer
new interlock then .....cheers
Jan 30, 2014 | Dryers
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
I have a 2007 Hyundai Santa Fe, the fuel door lever does not release the fuel door. What should I look at to fix this?
There is a latch inside the fuel door and it may be the case that the latch is a little bent or tight and when you hit the fuel door release the latch isn't releasing because it is bent.
Bend the latch in towards the door hinge a little bit at a time until it releases normally.
Hope this helps,
Cheers,
Dave
Nov 26, 2010 | Computers & Internet
I added too much weight to a load of clothes. Door popped open and now it won't stay shut.
You may have broken the door latch mechanism, or the door hook. The following link explains how to replace the door latch on a Whirlpool Duet:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
Replacements parts (if required) can be purchased from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is correct, the part number for a replacement door latch is 8182634. If the door hook is defective, the part number is 8181651. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please let me know. I hope you find this information helpful.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I replace the door latch on my dishwasher?
Don't try to bend anything! The latch mechanism in the door is probably broken. Open the door and remove the 11 torx screws holding the inner panel on. You will probably find broken plastic bits on the pathetically flimsy latch; mine failed after 4 years and I expect it to happen again.
If you do, see the link given in "I Have 3 problems with my dishwasher, my...",
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168615&diagram_id=1349844#d1349844 Unlatch the two switches and slide them off the old part and onto the new one, observing all the obvious precautions about not getting shocked and putting the switchess on correctly. Reassemble the door and latch with the screws.
May 23, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
Door latch broken- disassemble door ??
yes if its plastic just pop it out to replace
Feb 09, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Microwave r-140d
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 15, 2008 | Microwave Ovens
Hotpoint WMA46 Front Load Washer Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
