Question about Rio ReplayTV 5504 40-Hours Video Recorder
Replay does not power up
This system has worked fine for several years, now it will not power up at all, no blue light etc. I have checked the DC voltage to the HDD & it is not present, I have tested the HDD externally & it spins up & is recognized on my PC.
It looks like the P/S is defective but I can't troubleshoot further as I do not have a schematic diagram & can't find one online!
Any advice would be gratefully accepted
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
If you determined it is the power suppy, the but a parts replay off ebay and replace it. If it has a lifetime then worth fixing, if not just pick up a lifetime unit off ebay
Posted on Oct 27, 2009
On an ithw858 wireless the blue power light does not go on with nothing plugged in except the 5v power supply. What blue light part do I need?
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Jan 07, 2018 | Televison & Video
All running lights, dash lights and headlights on my 1998 Honda Civic LX flicker/surge when the car is running
hey Trenna.. well I'l try to be as simple as possible and take my time communicating with you until we can get a handle on it.. Normally this problem comes from the alternators rectifier circuit. Basically it controls the conversion from ac current to dc current. and the dipping lights suggest its dropping power.
now these lights get their power from the ACCESSORY system which is the same as what the cigarette and the factory radio gets its power from.. Follow so far ??
so now we have to look at 3 things..
The amount of power going to the system, (the alternator should always be pushing around 13.5 volts)
The kind of power AC/ DC.. (its always dc but if the rectifier or regulator is broken some ac will leak in)..
and for a short circuit in the wiring for the accessories.
can you get your son in law to double check his wiring and find the missing cigarette lighter wires, and also if he has a Volt meter to check the amount of current coming from the alternator to the battery while the car is idling ??
i know you said your not a car person so we will need some one to help out with all the testing work..
Btw the SRS light is the air bag click system located in the steering wheel. Its what triggers the airbags in case of an accident. Normally from constant turning these wires get broken and the clock mechanism needs to be replaced.
Dec 30, 2012 | 1998 Honda Civic LX
Animal Crossing Wild World wont work on my action replay
have the exact same problem with mine, except its not unkown, but the 2 white bars freezing and stuff. what you need to do is restart your AR by turning off the DS and holding start select and some other button then type in the game name and id again. than it should work just fine
Mar 25, 2010 | Datel Action Replay for Nintendo DS
Sound but no picture. menus work.
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Jul 12, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Gateway DC-T50...can't view or transfer images to my computer
how do i transfer pictures from my camera to my computor which has as its operating pro. vista?
Feb 09, 2009 | Gateway DC-T50 Digital Camera
Power/Startup Fail
There may be problem with some wire connections or RAM is loose in the slot. insure that RAM is perfectly tight in the slots.
Jan 03, 2009 | Computers & Internet
Not the power supply!
Hi
To help troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights lites solid green. The power button also lites solid green. If the computer malfunctions, the color and sequence of the diagnostic lights as well as the power button helps identifies the problem.
First, disconnect the power cord and remove all connections (Keyboard, Network, Mouse etc) as well as optional PCI Cards. Connect up the power cord (Monitor as well) and try powering the PC.
Check the diagnostic lights/system lights color and sequence and check the link below for more info (Assuming you have another system that can access internet)
Diagnostic Lights - http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
System Lights - http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1114432
Reply with lights color and sequence as well as any beep codes and I will respond at best effort.
Mike
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power - AC Adapter
12 volts DC-1 amp
center pin is +
Mar 13, 2008 | V-Stream Xpert 1280x1024 LCD TV Box...
Rio ReplayTV 5504 40-Hours Video Recorder Logo
109 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
Jaime Hernandez
JOHN TOPLISS
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
