Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Nordmende washer dryer not drying
When I select the dryer on the machine it runs however it doesn't dry and the clothes are still wet after an hour. I am wondering if you know why? Thanks
    New Friend:
Check that the heating element is functioning. Check thermostatic cut-out
Posted on May 12, 2014
  • 105 Answers
SOURCE: Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Posted on Feb 02, 2008
SOURCE: Equator EZ 2512 CEE Front Load dryer not starting
The mode light isn't blinking a fault code. It is blinking as if it is in the end of a cycle. But it is at the start of the drying cycle. The drying cycle never starts. The quick blinking is the program being accepted by the unit according to the user manual.
I did try counting the mode light and it blinks same interval uninterrupted for 20 min
Posted on Feb 20, 2008
  • 3 Answers
SOURCE: Dryer not working properly
its likely to be the condenser unit in the rear of the machine full with lint check for a large clear / opaque unit with pipes connected and make sure it is clear
Posted on Jun 19, 2008
SOURCE: Dryer cycle doesn't dry on Equator EZ3600 CEE
It's lint stuck in the dryer that drastically lowers the efficiency.
From another site I found the solution:
1. UNPLUG UNIT
2, remove 4 screws top back edge of top panel and lift off panel.
3. blower will be toward the right rear of unit. To save a hassle later, take a sharp object and scrib an index mark across where the blower meets the plenum, it will help you line it up later.
4. there are four 7mm bolt-head screws holding the blower and blower motor onto the heater plenum. One of the screw is almost impossible to see, but there are 4. I used a "flex-shaft" socket to get them out. This can be a real PITA.
5. carefully lift blower motor out of plenum. You will probably need to shove the whole tub unit to the left to get clearence. IF YOU OPT TO DISCONNECT THE BLOWER WIRES MAKE A DIAGRAM OF WHERE THEY CONNECT!!
6. I usually use a thin knife to scrape each of the vanes on the blower. Then vac everything out and use your hand to check for smutz in the plenum.
7. THE FAN ONLY FITS ONE WAY ON THE PLENUM. be sure to test fit to see if all the holes line up.
8. When motor is back in place, spin the little cooling fan on top of motor to make sure it's not binding. I usually test the unit by plugging it in and starting dryer to make see it runs.
9. Put top of unit back in place.
Posted on Nov 24, 2008
  • 163 Answers
SOURCE: Broken heater during the dryer cycle
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company (danfrogel@yahoo.com)
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
