Question about Conair WW60 Weightwatchers Scale
How do I calibrate a conair model ww31x scale?
SOURCE: Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Posted on Feb 20, 2009
SOURCE: replace battery
OK, I just (11/29/09) replaced the battery on Conair TH301S glass scale. You will need a CR2032 (3V) battery, a small (P12) phillips screwdriver, a flat screwdriver and a small twiser (to hold small screws).
On a stable and clean surface (kitchen table, no kids around due to small screws) lay flat upside down the scale.
1) Remove all 6 phillips screws that hold the inner frame.
2) With the help of the flat screw driver unhoock each side of the inner frame (horse shoe shape)
3) Open slowly because there are 2 wires that connect the weight sensors and lay flat on the side.
4) There is an eletrical circuit beside the display, it is being held by 5 very small phillips screws (remove them)
5) The you will find underneath a small round black box held by 3 phillips screws. Remove them, open slowly the top cover and inside reside the battery, pop it up gently with the flat screw driver.
6) Replace the battery, reinstall the 3 screws.
7) Where the display stand, remove the 4 screws of the plastic cover. Slowly remove the cover and the LCD display itself (pay attention on how the display is installed).
8) Re install the circuit board with the 5 smaller screws
9) With a QTips and alcohol clean the contacts of the circuit board where the LCD dispaly sits. Sit in place the LCD display (it will touch the circuit from above) .
10) Place the plastic cover with the 4 screws.
11) re install the frame and put the 6 screws.
12) YOU HAVE DONE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Nov 29, 2009
SOURCE: manual for Conair thinner scale model 205
change battery
Posted on Jan 27, 2010
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
SOURCE: Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Posted on Oct 10, 2010
Instuction manual for weight watchers by conair glass memory precision scale-model ww43d
Why ask me ?
I aint no fitness guru LOL
They dont have one on the conair site ?
Nov 29, 2011 | Weight Watchers Glass Electronic Scale
Second hand scale operating instructions
You can download the manual for the conair TH210 scale on the link below. If that is not your scale please give the make and model # so I may get you the right one.
http://www.conair.com/cnt_ib.php?action=download&id=798
Good Luck
May 13, 2010 | Conair TH210 Thinner Body Analysis Scale...
Lost instructions for bmi and special feature settings
Conair Support – Online Tech Help to Troubleshoot Problems
by: Guest1223497 in Conair Weight Watchers WW-87 Body Fat Glass Scale | 9 months , 28 day(s) ago | 10 ... Manual or Instructions for Conair CID502 Phone ...
livesupport.maybenow.com/Conair
Oct 04, 2009 | Conair Weight Watchers WW-87 Body Fat...
Why does my scale only display RON when I step on it?
I contacted conair about this problem below is the response.
Thank you for your email.
Simply mail us your defective product or part with a detailed letter stating your name,mailing address, model , serial number, a brief description of the problem , a photocopy of your receipt and a cheque made out to Conair Canada for Conair products($5.00) or Cuisinart Canada for Cuisinart products ($10.00) for return shipping. Your product will be serviced and or inspected for possible warranty repair or replacement.
Please note that all replacements will take from 3-6 weeks and will not be replaced immediately. They must go through are technical department for testing.
Please also be advised that we do not have a reimbursement or refund policy.
CONAIR/CUISINART CONSUMER PRODUCTS
100 Conair Pkwy
Woodbridge ON
L4H 0L2
Tel: 1-800-472-7606
Sorry for any inconvenience this may cause.
Regards,
Consumer Service Representative-CP
Mar 22, 2009 | Conair Weight Watchers Glass Digital Body...
Battery cover
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Nov 18, 2008 | Conair Thinner Scale by TH208 Body Fat...
Conair WW60 Weightwatchers Scale Logo
152 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
