Question about Zanussi Washing Machines
What is causing the burning smell in my washer / dryer?
Zanussi model zwd1472s washer and dryer- there is a burning smell coming from the unit during the drying cycle and it is not drying the clothes. The wash cycle is operating normally.
    Sergeant:
  • 255 Answers
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima Or Similar.
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores. What is causing the burning smell in my washer / d - causing-burning-smell-in-washer-dryer-04t3bj0jgktmuqmnt3s3ejb0-2-0.png causing-burning-smell-in-washer-dryer-04t3bj0jgktmWhat is causing the burning smell in my washer / d - causing-burning-smell-in-washer-dryer-04t3bj0jgktmuqmnt3s3ejb0-2-9.jpgoads/images/causing-burning-smell-in-washer-dryer-04t3bj0jgktmuqmnt3s3ejb0-2-9.jpg causing-burning-smell-in-washer-dryer-04t3bj0jgktmuqmnt3s3ejb0-2-20.jpg
Posted on Dec 23, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Sounds like the heating element is burning out.
best get a local (trusted) tech to have a look
Posted on May 31, 2014
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
eandlfan
  • 9 Answers
SOURCE: washer repair
The transmission might have locked up causing the motor to overheat.
Posted on Dec 23, 2007
JR JR
  • 116 Answers
SOURCE: empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Posted on Nov 30, 2008
SOURCE: Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Posted on Dec 02, 2009
pappapumpdaf
  • 635 Answers
SOURCE: MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Posted on Mar 24, 2010
Zanussi To 7103 S. Smell of burn coming from dryer,I clean filters on a regular basis wondering is there another compartment that I'm overlooking???
DRYER SMELLS LIKE BURNING:
Answer:First, Stop using your dryer until this problem is resolved. This is a fire hazard and could cause a fire.
Your issue is more than likely alint build up problem. The lint that comes off of your clothes as you dry them becomes trapped in the dryer itself and in the venting duct that connects from the back of the dryer to the wall.
The first thing to do is todisconnect powerby unplugging the dryer cord from the wall. Slide the dryer away from the wall slowly.Remove the hose ductthat attaches to the back of the dryer. Look inside the hose duct and if you see heavy lint build up, that is most likely your problem. If you have a shop vac vacuum or similar, use the long wand attachment tovacuum out the lintthat is in the duct. The best way to do this is to completely remove the vent duct from the wall and dryer.Vacuum the inside of the ductto clean it out. Alsovacuum in the vent hole in the wallwhere the duct attaches to the wall and remove any lint that may be blocking air flow. Put everything back together and test your dryer to see if the burning smell has been resolved.
NOTE: There may be heavy build up of lint deep in the wall. You can purchase aDryer Vent Cleaning Kitthat may make your job of cleaning the vent much easier. However, it may be best to call a Dryer Vent Cleaning Company as they have the equipment that is needed to remove all lint in the wall that could cause a fire. We know everyone wants to save money and "do it yourself" but when it comes to safety, money should not be an issue.
If the burning smell is still present, you cantake the dryer apartandtry vacuuming out any lintthat may be built up on the inside of the dryer. Do a search for your dryer model name and number onGoogleto see how your particular dryer model is disassembled. If you are not comfortable taking your dryer apart then it is advised to call an appliance repair company as your issue can cause a fire.
There are other reasons for your dryer to have a burning smell. There could be an electrical issue inside your dryer. This may mean that a certain part or electrical board is going bad or is bad. Another common reason for this issue is something is near the heating element inside the dryer and causing the burning smell. If you have an older clothes dryer, it may be possible that the components are past its life span and it is time to purchase a new dryer. If you want your dryer to be looked at by a professional, it may be time to call an appliance repair company to come out and check your dryer.
There are plenty of videos that can help you to determine what may be wrong with your dryer. There are a few videos below that may assist you with troubleshooting and disassembling your dryer.
May 19, 2015 | Zanussi Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Dryer makes a high pitch squeal and when you open the door it has a burnt smell.
roller/supports bad or idler pully sticking or drum ball support depending on model the burn smell odd can be caused by dragging during operation
Aug 20, 2009 | Whirlpool LER4634J Electric Dryer
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Zanussi wdj 1094 washer dryer
possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
