Question about Thetford Norcold DE0051 Refrigerator
Why has my vitrifrigo 5060 3 way fridge got no lights coming on and is not working could this be the fuse
Why has my vitrifrigo 5060 3 way fridge got no lights coming on and is not working could it be a fuse
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
May be fuse or may b in pawer plug
Posted on May 12, 2014
We don't know how to hold down our vitrifrigo fridge in our motorhome. There were no instructions with the fridge.Its a C130 I.
talk with a caravan service center but you can remove the rubber feet and front adjuster bolts and use those points to bolt the fridge to the floor of the motor home
advice from people who install fridges to vans and motor homes would be a good place to start
May 06, 2017 | Refrigerators
Frige-Freezer not coming on!
there is really nothing You personally can do to fix it, oyu will have to call a serviceman, i reccommend sears. It is a internal circuit or wire that probably blew and needs to really be fixed by a professional.
Sep 14, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
I can not get port to let me get in coming calls
Most likely your system has a firewall somewhere .
Could be the router. You need to log into the router and check TCP ports 5060 and 5061 are allowed in the firewall settings . ring your isp and ask them to help you get Voip incoming ports to work on your router for incoming Voip and tell them the device you are trying to use
Jan 01, 2015 | magicJack Plus
Fridge troubleshooting
The motor should not be running continuously. If it is, then it is because the internal temps are not going down low enough for the thermostat to shut the compressor down. If the temp is not low enough, the temperature of the coolant returning to the compressor is higher than what it should be and that the cool refrigerant returning to the compressor cools that motor down. If it does not, the motor will over heat and often shut down for cooling.
Ice buildup on the evaporator coils will cause a warmer running fridge. If the unit has a self defroster then it is not working and responsible for the anomaly.
Nov 27, 2013 | Refrigerators
Nothing works in fridge, not even the lights come on. electrical outlet is fine. fuse in fridge has dark spot but shows it is still viable
Try replacing the fuse ... did you test it with a volt/ohmm meter to prove it is good?
Thanks for your visit today.
Jan 06, 2011 | LG Refrigerators
Where can I get a user manual for my Olympus c-5060 wide-zoom camera?
You can download and print the instruction manuals in PDF format by clicking these links:
C-5060 Wide Zoom Basic Manual (11 MB)
C-5060 Wide Zoom Quick Start Guide (811 KB)
C-5060 Wide Zoom Reference Manual (9.6 MB)
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Dec 03, 2010 | Olympus Camedia C-5060 Wide Zoom Digital...
SonicWall 5060 will not reset to factory default
hi,
there is notch on sonicwall to reset it.
Mar 07, 2009 | SonicWALL Pro 5060F Firewall
Vitrifrigo 3 ways fridge in campervan not working on batteries
You can fit a relay connected through the vehicle ignition that will prevent the fridge running on 12V unless the motor is running, this way you will not drain the battery.
Jan 18, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Thetford Norcold DE0051 Refrigerator Logo
142 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
