Question about Bosch HES5042US / HES5052US Electric Kitchen Range
Bosch HES5042U error 160 - Bosch HES5042US / HES5052US Electric Kitchen Range
I have bosch clasixx 1000 express that goes straight on to spin, it bypasses wash.
Possible fault with the main controller unit, it can be that the processor is malfunctioning or there is a memory error.
choose from another program and see if there is any change.
If not remove power for few hours , if not there are errors in the controller.
Jul 25, 2012 | Bosch Classixx WFL 2066 Front Load Washer
My bosch dishwasher she6af02uc is showing an E-24 error what is this
error code E24 = Drain hose blockage or pump impeller failure, suppose running it with filter unsecured would allow some goodies to get in there.
Changing the fine mesh filter should fix this.
Jun 29, 2012 | Bosch Dishwashers
E:27 error on bosch 500 series washer
turn the dial to the off position. Hold down both the delayed start and spin select buttons and turn dial to the left one click (cold position). you should then here the door unlatch. let go of the buttons. you will see some other codes p 01, p 02. turn dial to off. it should work fine after this. it worked for me. this should be in the manual.
May 15, 2012 | Bosch WFVC6450UC 500 Series Vision Front...
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 09, 2012 | Bosch Dishwashers
Our Bosch Maxx 7 skips spin cycle of the washing program. The remaining time jump from about 7 minutes to 2 minutes
Possible that the program controller unit has some errors and so it does work erratically. Check on all connections to the program controller unit, check for moisture on the unit. Also remove power for few hours and see if there is any change.click on : washing machine tips
Mar 14, 2012 | Bosch Washing Machines
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
Nov 21, 2011 | Bosch Washing Machines
E17 error code
Got an E17 Error today on a Bosch 6450 Series washer (the user manual says Bosch Vision 300/500/DLX series). Here's what I did to fix the problem.
- Tilted the unit back, propped up the front with some 2x4 (lying flat; that's all the room I had).
- removed 3 screws (Torx 20 I think) under the front lip. Then slid the cover (below the washer opening) down. This revealed the pump to empty the washer, a manual door lock opening pull rod, and a drain line (?)
- Looking through some holes in the front panel I saw some water on the bottom of the washer... but I spent a lot of time with the pump cleaning it out first (some zipper pull got in there and made a lot of plastic shavings). - Ultimately I got my hand the bottom of the washer and soaked up the water that I could find. That's when I realized
- there is a micro switch mechanism at the bottom near the front. This must be the "AquaStop". The mechanism contains a bit of styrofoam that floats up on any little amount of water that collects under it and triggers the microswitch. So, I removed that unit, wiped the water up... put it all back together. No more E:17 error.
Still don't know how the water got there in the first place though.
Mar 29, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
My Bosch washing machine shows error code F37 and beeps
My Bosch washing machine shows error code F57 and beeps
Dec 09, 2008 | Bosch Logixx WFT 2806 Front Load...
Error code
Try unplugging or turning off the breaker for 30 mins then plug it back in and see if you still have the 160. I'm surprised that it doesn't have an F anywhere in the code. How old is the oven. Could some of the lights on the control be out. they are LED's and sometime they do burn out. I'm thinking this could be an F06 code which could mean anything from a power surge (clock) and needs to be reset (like I said by switching of the breakers or unplugging) to an EOC (Electronic Oven Control) failure. By switching off the oven and waiting about 30 mins. if it doesn't come back on it will be the EOC. make sure the LED (light emitting diodes) aren't out on the control making you
Dec 20, 2007 | Bosch HDI7282 Dual Fuel (Electric and Gas)...
Bosch HES5042US / HES5052US Electric Kitchen Range Logo
32 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
