Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a B&S 22hp Intek v-twin on a craftsman mower. It starts fine, runs great, but after about 10-15 min it starts skipping and will finaly die after another coupl min. As if it was running out of fuel. When I look at the filter it has like 2 dropps of fuel in it. I didnt know how it was running at all. I changed the filter and had the pump tested and it still happens. What should I try next?
Mine did exactly the same thing until I figured out the replacement fuel cap I bought wasn't vented.I put a vented one on and away I went.Also check for a collaping fuel line,and check the screen inside the gas tank,those corrode sometimes.Hope that helps !
Posted on May 12, 2014
kel1guy2002
  • 3740 Answers
SOURCE: My 20 hp Intek v
Hi and welcome to FixYa. I am Kelly. What your describing is a fuel starvation / lean fuel mixture symptom.
First off remove the fuel supply hose to the carb and check fuel flow. It should be a normal gravity flow rate. If you don't have flow check the bottom of the gas tank for debris. I note you already changed the fuel filter and pump.
--Check to make sure that the fuel solenoid on the bottom of the float bowl is working correctly. You can unplug it and then test it with battery power to see if the plunger is moving.
--Also check it in place for 12VDC with the key on and seat switch activated (if installed).
Your parts list can be found here:
http://www.briggsandstratton.com/document/index.aspx?doc=MS3562_C_LO.pdf
The solenoid is item 947A of the above link. (pdf file page 5 top right)
With the fuel hose connected float bowl removed you should also chec the fuel float needle item 105 for proper operation. Float down... fuel flow.... GENTLY lift the float to LEVEL there should be no fuel flow.
These are the 2 most common problems:
Either the fuel bowl solenoid is not being energized / not working or.... (item 947)
There is debris in the needle and seat. (Item 105)
If you do not have 12VDC to the fuel solenoid you will have to find out why. (Safety switches.. broken wire etc.)
Before you reinstall the fuel solenoid clean the area with carb cleaner.
Thanks for choosing FixYa.
Kelly
Posted on Sep 28, 2010
SOURCE: 24 hp briggs intek vtwin won't start
This same thing happens to me and I resolve it by taking the gas line off in front of the carb and blowing air through it.....then it will run fine. I realized I could do this when I took the air cleaner off and fed it gas manually and it ran fine....and I also had gas pumping through the fuel pump. I'm not sure of the problem....either the fuel pump is losing power or their is something blocking the carburator intermitantly
Posted on Jul 14, 2009
  • 553 Answers
SOURCE: 18 hp briggs & stratton intek i can get it
Check the choke, if that doesn't work the old gas may have left residue that is plugging your ports.
Posted on Jun 08, 2010
SOURCE: I have a John Deere
Maybe one of the safty switches is bad, by pass them one at a time to see if that will take care of it. If not, maybe the coil is bad.
Posted on Mar 04, 2011
canwoodjc
  • 3301 Answers
SOURCE: mowing and running fine. just
0.030
Posted on Jul 15, 2011
Riding lawn mower starts runs good for a out 15min then stalls and dies. Few min later starts up then same thing.
shortage of fuel is indicated
check for full flow to the carby
next is faulty coil --overheating
make sure that the cooling fins are not blocked with old grass and muck
Jun 25, 2017 | Craftsman Garden
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22hp intek eng stalls when hot starts and runs fine until it gets hot.
you have an overheating problem with your motor then. take it to the shop and have them check it.
Jun 30, 2009 | Craftsman Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
226 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
