Question about Garden
I need to know the length of belt required for a mastercraft 15 hp 46 inch deck. the belt drives the blades
I have a mastercraft riding mower. I am looking for the length of belt needed for it that drives the blades. CTC Model number 60-1808-8
    Habit-Forming:
  • 40 Answers
Take a string and palce it as you would the belt, then measure the string
Posted on Jun 18, 2014
  • 7 Answers
SOURCE: weedeater 12.5 hp 38
thats a ayp deck.
the 38 and the 42 take the same belt
Posted on Sep 05, 2008
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Why burning belt on 48" Craftsman riding mower
Since you mentioned "48-inch riding mower" let's assume your question is about the mower deck and not the overall mower or its main drive belt (if manual shift-on-the-fly model). If the belt burns that means it is running but slipping against something; or that the drive sheave us turning against an impeded belt. In the first case the belt will be burned along its length; in the second the burning will be occuring in one location(s) along the belt. In any case of belt slippage, check first that all tensioners (springs) are properly in place and not broken or fatigued and in need of replacement. The only other thing would be resistance to belt running, such as:
blade blockage; blade rotor resistance from lack of grease or ruined bearing in need of replacment; grass clogging on deck underside or under blade drive pulley on deck top side; a pully sheave out of round; an obstacle between belt and sheave that is preventing free turn of sheave and belt run; misrouted belt; an overstretched belt that cannot be sufficiently tensioned. Inspect and correct or replace as needed.
Aug 19, 2014 | Craftsman Garden
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Route mower deck belt on 46" deck with 3 blade pulleys & 1 ideler pulley
what is the problem?
What direction (CW or CCW) does the engine drive the pulleys looking at it from above?
Do you have the correct length belt for it?
One thing is certain; if the idler floats (you cannot lock the position of the idler and it is spring loaded), then the slack end (non loaded side of the belt), is where the idler is positioned.
You need to know what direction the drive is to route the belt.
Nov 01, 2013 | Garden
Blade route
I can't give you an answer on this without knowing the model number of your mower.
Sep 25, 2013 | Mtd Oem Deep Deck Belt 46"
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Huskee riding mower- 18.5 hp with 46 inch cut. The mower has 3 blades. When I engage the blades the belt squeals but will go ahead and cut until it gets hot at which time it will stop pulling. The...
check the pullie blade bearing if it is going out it would make the belt squeak and when it gets hot it will make the motor lug down I have worked on mowers for 41 yrs.
Aug 14, 2011 | Garden
Bought a new husqvarna 46 inch cut mower today notice that deck has a lot of vibration in it
Tighten the belt that drives the mower blade. You can do this through the adjuster next to the pulleys and the blade-holder driveshaft. It's the one where the belt runs through, the smallest pulley/roller with an adjuster arm.
Try doing this without flipping the mower on its side. You might be able to access it opening the seat, then the cover.
Aug 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Unable to find the Troybilt deck V belt that fits my 2002
If it's the belt that just runs on the deck and not the one that goes to the engine, it is a 954-0349
Jun 24, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
