Question about Kenmore 5.1 cu. ft. Chest Freezer - White
Why does my Kenmore Freezer, Model 29502 only 2.5 years old, not cool below 34 degrees?
I noticed the temp gauge read 34 degrees with quite a bit of frost, so I defrosted it and it has been running for 24 hours an is only at 34 degrees. I have the thermostat at max and the motor is running.
4 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
breddi2
  • 126 Answers
SOURCE: My Kenmore freezer, model #253.9280212 runs but
The first thing to check is door gasket< bad corners,gap in side,bottom or top. Close door on a dollar bill and try to slide it top to bottom side to side and if it slides fairly easy then seal is not doing good. If you find dirty area clean it off along with the cabinet side as well.If you find the side is leaking then heat gasket with hair dryer and apply vasoline to gasket to help it move freely. If you find tear or hole then replace it.
Posted on Apr 22, 2009
richroth
  • 9472 Answers
SOURCE: Kenmore Freezer 106.727581: The freezer ices
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Posted on Aug 21, 2011
Our Kenmore 253.28432801 is just over 5 years old. It stopped freezing, and the Sears tech says it has a leak and needs coils and a condenser. This would be $618, he suggested we buy a new freezer. Co
If it's holding at 28 degrees, it's not the coils. See if dropping the temp does any thing to lower the temp. If it does, fine. If not, most likely just the control needs replaced or just cleaned.
Nov 15, 2014 | Kenmore Freezers
Freezer only cools to 34 degrees Took outside ,cleaned out still not reaching proper temperature(10 to -10 F). Hovering around mid 30"s. Problem first noticed when nothing would freeze in doors. Seal...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 01, 2011 | GE 20.3 cu. ft. / 575 liter Upright...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Kenmore upright freezer quit freezing would work intermitantly and then quit cooling altogether, Approx 10 years old trouble shooting advise or most likely cause would be appreciated
Sorry to read about your problem. you can have many different problems.
Here are some areas to troubleshoot
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. for compressor issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore 5.1 cu. ft. Chest Freezer - White Logo
132 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
